Results 1 to 13 of 13
Thread: vr ute bug catcher
    vy ss ute daily hj gts project
    Aug 2008
    Default vr ute bug catcher
    hi everyone i've been playin with the idea for a while of making a custom twin throttle manifold for my buick v6 and just want your opinions on it.
    basically the plan is to take the old manifold and cut the top off it. Then i was going to put a like a cube chamber on top to distribute the airfolw. The 2throttlebodies would come out vertically and poke through the bonnet with an old school bug catcher scoop on top.
    I've included some basic pics to give you the general idea, so what do you think good? gay? rice? be honest please thanks
    also wanted to add my car has an aluminium roll bar and stainless side skirts so the shiny scoop shouldn't look to out of place
    Attached Thumbnails Attached Thumbnails vr ute bug catcher-scoop-commodore.jpg   vr ute bug catcher-bug-catcher.jpg
    VSII 3.8L Ute
    Mar 2009
    It looks good there but I just can't picture it on a VR..
    I think if the VR was kitted, lowered, mags, and in general looked really mean, then you could probably pull it off, but on a unkitted VR I don't thinkso..
    It would definately suit a ute much much better..
    I think the VR and VS sedans are a bit hard to do sometimes
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    yeah i can kinda see it.... i reckon as long as its just sticking out of the bonnet i would look nice
    Aug 2008
    yeah because i drive on dirt all the time (as much as i'd like to) i can't really put a kit on it would just get trashed as i said i have the skirts and rollbars and its ridin on superlows all round so its pretty low.
    I would sit the bottom of the bug catcher at the front pretty much level with the bonnet
    VSII 3.8L Ute
    Mar 2009
    sorry, I meant a kitted sedan, you have a ute, I don't think the utes need a kit to look tough, I think once lowered, they aleady look quite mean..
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    it has been done, and there is a thread possibly in the v6 modi & developement that i posted pics up of a vr with the same setup as your wanting. twin throts and bugcatcher.
    EDIT: Ok had a search for that thread, looks like its gone.. so here are the pics.. first 5pics are with out throts, basically bug catcher tacked on to plenum, plenum modified somehow, and the 6th pic is of twin throts and i believe its just under a scoop on the bonnet.
    Now the bug catcher becomes your throttle hence the linkages and butterflys, so you wouldnt actually need to use standard throttlebodies, just mod your plenum attach bug catcher and away you go. If you still wanted twin throts you would need a scoop (like in 7th pic) becoz its only a scoop and not a throttle body like the bug catcher
    Attached Thumbnails Attached Thumbnails vr ute bug catcher-vn-20v6-20triple3.jpg   vr ute bug catcher-vn-20v6-20triple4.jpg   vr ute bug catcher-vn-20v6-20triple5.jpg   vr ute bug catcher-vn-20v6-20triple-2.jpg   vr ute bug catcher-vn-20v6-20triple.jpg   vr ute bug catcher-x7000011.jpg   vr ute bug catcher-dsc00096.jpg
    VS ute
    Nov 2008
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by ephect View Post
    Quote Originally Posted by Ross D. View Post
    any idea what the thread was called?
    think it was lost when we JC had a server failure, but as posted above, i've posted all the photos again
    VP ute
    Mar 2006
    Lots of dirt is not cool.
    I drive hundreds of ks a year on gravel and dirt. The air filter is grotty as from it each time. Even fourbies with snorkles are going to get dirty. Having it that close?
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    seriously dude... not worth it ... if your going to do that get a harrop manifold and go all out ....driving around on dirt with a suction pipe sticking out your body into your inlet manifold = Badddd
    SIR LS1
    the two ton go kart
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    that thread is definatly gone i had picks in it and they arnt here no more it was the big crash that lost them.i like the idea myself but ide go with the 3 petal bugcatcher and twin T/B's as the bugcatcher by itself wont regulate airflow enough at small tps settings.habe a look on youtube theres 3 vids of vn's with twins straight up out the top of the bonnet need a good tune they run lean as and ping from all the extra air they let in
    Aug 2008
    thats what i was going to do twin TB's with either two small pod filters and the scoop or make a panel filter fit over the top like in the pics and i've realised that it might run lean so i'd probably have to get bigger injectors
    в∞ѕтεכ √&
    Jul 2008
    NZ
    just a tune should be enough the stock injectors should handle it .
  1. WTB: Mr Gasket bug catcher
    By Nos_VQ in forum Swap / Wanted to Buy / Trade
    Last Post: 09-04-2006, 09:21 PM
