Results 1 to 19 of 19
Thread: !!cant get ***** kick panel off.. help please!!!
    vr executive
    Nov 2008
    Default !!cant get ***** kick panel off.. help please!!!
    hey guys
    i jsut bought a chip and am trying to put it in this morning but the problem is i cant even get the kick panel off to acces where the chip is. i unscrewed the little screw under the glove box but its not giving pay
    please help guys
    cheers
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    you need to remove the strip that locks the doorsill to the kickpanel. remove the side airvent that attaches to the dash, and u'll see another screw behind there. i cant remember if i really needed to, but i removed the glovebox coz there was a screw underneath.
    vr executive
    Nov 2008
    ok so i finnaly got the kick panel off
    and now im faced with a steel box with rivets i think.
    how do i get this thing off?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    there are black clips around the ecu, gently unclip them and you can remove the ecu from its mounted position.
    on the other side are 2 screws holding a metal door/flap, remove them and you can lift the door up/off and under there is the chip.
    vr executive
    Nov 2008
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    From memory they are torx screws. They shouldn't be tight though, you might manage with a jewellers screwdriver.
    VX SS M6
    Jun 2005
    DENDTS's Avatar
    DENDTS is offline speedhunter
    VS SS series II
    Dec 2008
    airport west
    vr executive
    Nov 2008
    wow ive never heard of a torx screwdriver
    is there any other tools that would be able to get it off as i dont ahve any torx screw drivers?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    you might be able to get them off with a flathead screwdriver thats the right size, but you might end up wrecking the thread. will work thou.
    Jun 2005
    sounds like you might have that shield thing in front of your ecu. you will have to drill the rivets out. ecu is behind it. did vr's have this shield?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Not sure, i thought they had the small bolts like VN's and VP's, and then the VS's had the torx screws? If it does have the torx screws, you can buy a torx screw head set from supercheap / autobarn / repco for sweet F/A.
    It's a good investment. I hope you didn't buy the chip off Ebay.....
    -ToM-'s Avatar
    -ToM- is offline Bow Down to the Emperor!
    VR Exec [EMPIR3]
    Jan 2008
    SA
    the ECU isnt in the kick panel, its the PCM.
    you unscrew the bracket and unplug the pcm first.
    once you have that out the pcm slides out of the bracket, and then you open the metal container with a torx screwdriver
    Jun 2005
    Quote Originally Posted by -ToM- View Post
    yes it is...
  15. #15
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    ecu pcm same
  16. #16
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Quote Originally Posted by stocky View Post
    yes it is...
    Quote Originally Posted by ephect View Post
    ecu pcm same
    Saved me having to say it.
  17. #17
    Jun 2005
    isnt the pcm on the drivers side
  18. #18
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    BCM is on the drivers side
  19. #19
    Jun 2005
    BCM is underneath the instrument cluster. theres another box in the drivers side kick panel
  1. Air Filters K&N Panel VS Lukey Panel
    By BullittSV6 in forum The Pub
    Last Post: 18-06-2010, 05:21 PM
  2. removal of side kick panel
    By HRVATSKI_VOJNIK in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2008, 06:39 AM
  3. Black box, drivers kick panel...BCM?
    By Chirpstr in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-05-2008, 10:25 PM
  4. Kick Panels
    By Nev in forum Electrical Wiring / Questions
    Last Post: 21-07-2005, 12:41 AM
  5. Kick Down
    By daggett in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-12-2004, 02:01 AM
