Results 1 to 12 of 12
Thread: Coolant issue with mates car
    VR Commodore Exec
    Oct 2007
    Ballarat
    Default Coolant issue with mates car
    Hi guys, Yesterday at footy training my mate asked me if i could look at his car. He said that it was running a bit hot so he checked the coolant level and there was none in the resevoir so he filled it up(half with coolant half with water cause he ran out of coolant). Anyway he told me that he drove it about 15km to training and back and he checked the level and the resevoir was empty. I checked his oil and there was no sign that water could be leaking in there and i went over the lines roughly and it didn't look like there were any crack or leaks. He has a stock VR, he only asked me cause compared to him i know heaps about cars lol.
    Does anyone know what could be causing the coolant to go so quick?
    Any help would be great. Cheers!
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Check the OIL, Hopefully it's not bubbly and thick!
    Fill it up, run it for a minute, Look for leaks, Specifically, check above the harmonic balancer (the big pulley at the bottom), if the water pump is leaking you will notice it there!
    Check hoses and the around the radiator.
    Also, check above the radiator cap (on the bonnet) - is it wet? Might need a new cap.
    Good luck.
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    VR Commodore Exec
    Oct 2007
    Ballarat
    I checked the oil and it looks fine, looks normal. I will fill it up and run it and see if i can spot any leaks.
    KhaosInc is offline Donating Member
    VR Executive
    Jul 2005
    Bris North
    check between the heads and intake as the intake gasket craps itself and it can leak into the intake or sit where the intake/heads join together... mines crapped itself on the drivers side.
    ive read somewhere if you need to change it you will need to change the oil too cause some coolant will leak into the valley when the intake manifold is off....
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    check your water pump mate i had this problem not long ago water pump is about a $140 fix not sure about vs im assuming it would be the same as my vr the water pump is directly above the harmonic balancer theres about a 6mm hole underneath the pulley and f the seals shaged it pisses out tell your mate NOT to drive it untill your sure its not the water pump you can seriusly **** shit if ur engine over heats
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    vs commodore
    Oct 2008
    i agree had same problem, water pump, easy way to check, just sit a piece of paper under the pulley's roughly, after a while if theres coolant or a big wet patch there, theres a good chance you've got a hole in the pump. hope its that, there easy to fix, just need a new one.
    addicted to commodores
    VR Commodore Exec
    Oct 2007
    Ballarat
    Thanks guys i'll check and hopefully its the water pump. He told me that he filled the resevoir up with just water then the next day he checked it and there was coolant in the resevoir because it was green. Does this mean anything?
    VS 3.8l Exec
    May 2006
    Ya mums house!!!
    if there is coolant in the res then this is normal operation, basically as the pressure builds in your radiator the density if the water changes causing it to purge into the res, this has an opposite effect if yor radiator is running low the back pressure cause the water from the res to flow into the radiator... now if there's flowing problems i would look at the thermostat needing to be replaced, or the water pump... these are both quite easily fixed...
    VR Commodore Exec
    Oct 2007
    Ballarat
    VX Calais
    Jun 2008
    SA
    could also be a stuffed radiator......mine was "drinking" coolant for a few weeks, then one day i had the bonnet open while the motor was at operating temp and found steam coming from the radiator. turns out that the radiator core had sprung a leak as there was coolant staining along one of the tubes about halfway down the radiator
    might also pay to check the heater tap, common fault for this model!
    VR Commodore Exec
    Oct 2007
    Ballarat
    It shouldn't be the radiator as it had a brand new one installed about a year ago. I'm pretty sure its the water pump i'm just gonna ask my old man to be sure.
    VS Clubsport series I, VY II R8 Clubsport
    Jan 2008
    Sunbury, Victoria
    Quote Originally Posted by MG's VH Wag View Post
    He said that it was running a bit hot so he checked the coolant level and there was none in the resevoir so he filled it up(half with coolant half with water cause he ran out of coolant). Anyway he told me that he drove it about 15km to training and back and he checked the level and the resevoir was empty. Does anyone know what could be causing the coolant to go so quick?
    It sounds as if If you only filled the reservoir, If so you wouldnt have possibly topped the radiator right up! Basically yuou need to fill the radiator and bleed the engine to get rid all of the air, then top up the reservoir...If the water still drops its level then you have an issue/ leak if the level is good after filling and bleeding job done. My VR Calais V6 had this same thing when I ahd it, and when i fully topped the radiator,and bled the system it was perfect after that!. Might be worth a look as the water level will keep dropping if you are only topping the reservoir up!
LinkBacks (?)
  1. 09-06-2009, 01:20 AM
  1. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  2. mates vr
    By VY ACCLAIM WAGZ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-04-2007, 06:40 PM
  3. Mates VZ S Ute
    By AirStrike in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-10-2004, 06:27 PM
  4. what mates do
    By Troy711 in forum Jokes/Humour
    Last Post: 23-06-2004, 12:30 AM
  5. Mates Vn
    By The1985divo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2004, 08:13 PM
