Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: what t peice do i need? help needed asap
    PSYKO PHOENIX's Avatar
    PSYKO PHOENIX is offline AHHHH brain fart
    1995 VS Commodore v6 ecotec
    Nov 2008
    rotorua, NZ
    Default what t peice do i need? help needed asap
    hey guys, ive spent months and months trying to get this bloody sandwitch adapter to work with the oil filter etc, but it hasnt worked, i cant afford a filter relocation kit at the mo so im gunna have to go for the t peice
    heres the guestion
    i want to mount a oil pressure and oil temp sender, what is the name/size of the t - peice that i need to buy?
    (95 vs commodore, ecotech v6, 3.8 - incase you were wondering)
    i need an answer asap so please any help would be brilliant!!
    you dont turn a holden off
    you power it down!
    for any one who asks, holdens dont leak oil, there marking there territory
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    i have one in stock. can do it for about 15 dollars.
    SIR LS1
    the two ton go kart
    Nov 2008
    rotorua, NZ
    sounds good to me!!
    how much to send it to rotorua, NZ
    how soon will it arrive??
    you power it down!
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    231-088 is the part number, its a 1/4 thread. VDO brand.
    cheaper to get it in nz mate as postage will cost more than the t piece itself
    hope thats been some help
    SIR LS1
    the two ton go kart
    Nov 2008
    rotorua, NZ
    cheers bro! thanks for that!!
    if i was in aus id def be pickin it up off you!
    thanks for your help!
    you power it down!
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    Nov 2008
    rotorua, NZ
    thanks again!
    1 more question tho
    obviously im only gunna have the aftermarket pressure and temp sender attached to the engine, what do i do with the old stock sender? and will the oil light be constantly on on the dash?
    you power it down!
    Nov 2008
    rotorua, NZ
    or new brian wave!
    can i rewire it so the new aftermarket sender is wired not only to the oil pressure gauge but also to the stock oil pressure sender and thus the ecu and oil pressure light??
    you power it down!
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    get a t piece, put the factory sender in the top of it and put your aftermarket gauge line in teh side of it ...
    search for my ute and u will see where i mounted my gauges
    SIR LS1
    the two ton go kart
    Nov 2008
    rotorua, NZ
    and what about the oil temp sender?
    you power it down!
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    id say you will need to run a sandwhich plate man. maybe try a different oil filter on teh sandwhich plate
    SIR LS1
    the two ton go kart
    Nov 2008
    rotorua, NZ
    thanks mate, any recomendations??
    you power it down!
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    dont see why u cant run a T piece where the original oil sender is and have ur aftermarket one hanging off the side?
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by ephect View Post
    He wants to run 2 gauges - oil temp and oil pressure each requiring their own sender.
  15. #15
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    he is running a t piece with factory sender and pressure gauge, but wants oil temp as well. u needa use teh sandwhich plate
    SIR LS1
    the two ton go kart
  16. #16
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    missed oil temp, was thinking coolent temp, run a + adaptor?
    EDIT:thinking about it, a sandwhich plate is the better option
  17. #17
    Nov 2008
    rotorua, NZ
    yup it sure is, the only problem is that with the sandwitch plate on it the oil filter dosent fit, cuz the male part of the adapter is to long and the filter wont line up (engine mounts are in the way)
    and before you say get it cut down, i allready have, by 5mm and it still to long (i dont wanna trim it down any further)
    so im back to square 1 - slaming myhead into a wall that is
    you power it down!
  18. #18
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    i allways put oil temp in the sump with a threaded bung.you would need good fresh flowing oil going past the oil temp sender to actually get a reading in the T-peice is just stagnant non moving oil so i dont think you would get any worthy figures from it.T-peices can be had from engineers shop or hydrolink mate cheap as.can join as many together as you need for outlets.
  19. #19
    Nov 2008
    rotorua, NZ
    so its either drill a hole in the sump and thread it for the temp sender or, use a sandwitch adapter?
    ive allready got the sandwitch adapter but its fitting the all important oil filter thats the big problem!
    you power it down!
  20. #20
    в∞ѕтεכ √&
    Jul 2008
    NZ
    will the filter fit in there once its on.maybe just fit it up with the mount loosened off then put the mount back on
  21. #21
    Nov 2008
    rotorua, NZ
    tryd it, but i cant get the 2 on tight enough, i dont wanna run any risks of it being 2 lose
    you power it down!
  22. #22
    VR S Pack - 5 speed
    Sep 2008
    Moorebank
  23. #23
    Nov 2008
    rotorua, NZ
    how hard/dangerious is it to DIY?
    you power it down!
  24. #24
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    highly reccomend to get it done by a mechanic man
    SIR LS1
    the two ton go kart
  25. #25
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    u'd wanna remove the sump from the engine, as you dont want any metal bits flowing round your engine thats for sure. some ppl have poored old oil or really thin oil thru it whilst drilling to flush the shards away, but i just wouldnt trust it. remove it, drill/tap it, clean and reinstall or take it to a mechanic, although i cant garrentee that he wont drill it still attached to the engine.
    dont see why u cant use a T piece or 2 of em, u will get a good reading and although you wont get a heap of oil flowing in there it'll still be accurate.
  1. Vs gearbox (help needed asap)
    By vs_lover in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2007, 05:59 AM
  2. Wiring Diaggram needed asap
    By V8VLWA in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-04-2007, 06:31 PM
  3. Help needed ASAP wit wiring loom
    By mako86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2006, 07:40 PM
  4. Electrical problem? HELP NEEDED ASAP!
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-12-2005, 02:30 PM
  5. Help Needed ASAP - Fuse Blowing
    Last Post: 27-09-2005, 05:06 PM
