Results 1 to 4 of 4
Thread: Lifter Noise of passenger bank
    vr berlina
    Oct 2007
    Sunny Coast
    Default Lifter Noise of passenger bank
    Hey guys. Just bought a VS Berlina, 161,000kms on gas $1500, with a blown head gasket. An absolute gem every thing is in great condition.
    So i did the norm and pulled the engine down, decked the heads, re seated the valves bought a VRS kit. All new gaskets.
    Started the car and let idle, check the vitals all is good BUT i have a passenger side top end knock. I presume it is a lifter. So i removed the rocker cover and the rockers and there was not much oil on the top end; cleaned all the galleries and pushrods re assembled and still have the knock. The motor had not run for 2 months.
    Has anyine had the problem before
    All GO
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Have you checked that it's not an exhaust manifold gasket leak or a crack in the cast iron manifold? Not much oil on the top end kind of indicates low or no oil feed to the lifters on that bank...maybe the oil pickup filter in the sump is blocked.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Even though the noise is only audible on the passenger bank have you checked the oil supply to the rockers on the drivers side aswell? What grade of oil are you running and I assume when you reinstalled the pushrods the oil way through them was thoroughly cleaned?
    vr berlina
    Oct 2007
    Sunny Coast
    Thanks for the replies lads but it ended up being a cam bearing that shit it self. bummer
    All GO
  1. Lifter Noise
    By sparkymac in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-07-2008, 12:23 PM
  2. is this lifter noise? or timeing chain..or neither
    By jas98 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2007, 08:08 PM
  3. Noise from front passenger wheel
    By cartoonwally in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2007, 09:44 PM
  4. lifter noise
    By pizzo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-05-2005, 10:14 PM
