Results 1 to 7 of 7
Thread: VR Auto - Manual Engine - any differencies?
    Sep 2004
    Default VR Auto - Manual Engine - any differencies?
    Hey
    Can anyone enlighten me on the differencies if any between the manual and auto engines in a VR? I've been offered a rebuilt auto engine - but have a manual in my vehicle. I know the starter motors are different - but is there anything else that would cause a problem fitting it in place of the manual engine?
    Cheers!
    C.
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    well if (and im guessing this is what you want to do) you want to put a currently auto engine in your manual car, all that needs to be changed is the STARTER MOTOR. Then you just needa fit the gearbox onto it and thats pretty much it mate. Cake as cake.
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    StockoVRWagz's Avatar
    StockoVRWagz is offline Formerly White50L
    '94 VR Wagon
    Feb 2008
    Northern Suburbs, SA
    Sep 2004
    Quote Originally Posted by Social View Post
    Thanks!
    Should have pointed out it's a V6.
    May well go for it :-)
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    a vr auto has a cam angle sensor where as the manual doesnt.
    im unsure if the actual sensor is still there on a manual motor. but i know from the ecu side of things the auto uses one but the manual does not.
    this is ultimately not needed for the car to run etc.
    but you may get fault codes and need to get a tuned memcal to get rid of your check engine light
    social's Avatar
    Nov 2008
    South Aus
    haydz, the engine itself will be going in to the alredy manual setup, so the computer wont need to be changed he'l be all good
    VR S Pack - 5 speed
    Sep 2008
    Moorebank
    yea the manual engine has the cam angle sensor too... it just isnt plugged into anything..
    you'll need to put a spigot bush in the crankshaft for the input shaft of the gearbox to sit in.. the auto engine wont have that in there.. and the bracket on the bottom of the engine that the gearbox bolts to you will have to take this off the old engine and put it on the new one.
  1. manual v6 vn engine is different to an auto vn v6 angine??
    By kwik6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2010, 08:55 PM
  2. Can auto engine go on manual box
    By spunkykpc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2008, 01:05 AM
  3. Engine Swap -- Auto to Manual Possible?
    By social in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-11-2008, 07:40 PM
  4. Fitting Super6 engine (auto) to manual
    By randolph in forum V6 Development And Modification
    Last Post: 04-08-2008, 08:13 PM
  5. vn v6's auto manual different engine?>?
    By kwik6 in forum V6 Development And Modification
    Last Post: 09-04-2006, 10:08 AM
