hey guys im replacing the swaybar link arms this weekend, i was wondering is there anything i need to do/look out for and if theres any tips or tricks to getting it done properly?
its the first time ive done this btw
you dont turn a holden off
you power it down!
for any one who asks, holdens dont leak oil, there marking there territory
easy just have a jack on hand to push up the strut when inserting or removing the old bar, and if your replacing the bar cut it with a hack saw, saves a shit load of time
Take note of which way the cup washers go, a lot of people put them back on the wrong way around.
MY RIDE
sounds good, ive been reading how to do it in the gregorys manual but its a lil confuzing and im not sure its even the right thing, they call it a stabaliser bar/arms, im i reading the right thing? as per usuial im a perfectionist and i wanna make sure i get it all right before i even attempt it. im not replacing the whle sway bar, just the link arms, with some nolathane ones
http://www.nolathane.com.au/catalogu...te%200505A.pdf
you power it down!
not hard. you just need two spanners to undo and redo the nuts. you will see 2 flat parts in each link pin. use a spanner on that to hold them in place
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
