Hi Guys,
My wife has a VS commodore and the power steering pump is noisy so I am about to replace it. I have bought a new AC Delco pump, and it has a 24 month warranty, however it says "warranty not valid unless a filter is fitted to the return line"
The VS doesn't have a filter inline with the power steering pump at the moment.
What sort of filter do I need? Where do I buy one? Does having a filter inline make the steeering heavier? Are there any disadvantages to fitting one? Should I worry about it, or just refit the new pump and not worry about a filter?
Any advice about this filter would be great.
Thanks,
John.
Thats a new one on me.
I did my pump about 5-6yrs ago with a genuine Holden one and don't remember anything about fitting a filter for the warranty.
If you bought it from a Holden dealer then go back and ask them, after all thats who you will return it to if it fails.
Good luck finding one and when you do post some pics.
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
There are in-line filters that you can buy for power steering (they look a little similar to a fuel filter). Bit difficult to find a location. One was fitted for me when I had the rack replaced in my VS Calais.
ive seen one fitted to a VS, looked like they cut the hose and shoved it inline
Got 1 on the old VH will get a pic.
Pedders rack.
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
My VS II Berlina Wagon
MY12 II SV6 Sportwagon
I had one on my Vs statesman it was on the line near the rail,just pick a spot thats not going to hit anything and cut the line
magnefine filters aussie made works for both auto and powerstear so good it can make dirty trans fluid look like new again do a google search they are great.i use them all the time you can weld a bung in the auto trans pan and not haveto replace the filter for ages if ever.
Mates VN had one right next to the tank i know there different but good idea!
He's car had done 400,000Klm's an the same power steer pump and was perfect.
Hi mate, Repco sell them, they are an inline unit about 3cm long and 1.5cm round, you just cut in the low pressure return line and feed it on both ends, add some clamps if needed. I did this on mine, an 8, with no probs. I think they cost about $25-30.
