Results 1 to 2 of 2
Thread: vr berlina heaters
    vr berlina
    Mar 2009
    Default vr berlina heaters
    i have vr berlina my heaters wont work at all it has climate conrtol someone help please
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    You either have a vacuum problem, your heater tap is siezed, the air mixer isn't working, or it could be something more mysterious. There is a member called Wavez who has been having a few problems. You should start by doing a search of the JC site, there is plenty of info out there, unless you feel that your problem is different.
    Quickly - a few things to check (since you have climate control):
    Does the air change from the centre to floor vents when going up a hill?
    Yes - vacuum problem, check for leaks and vacuum solenoid block operation.
    No - your vaccum might be ok, go to next question.
    Get the car warm, set the CC module to Hot and check the heater pipes (two brass coloured pipes) behind the CC module, above the drivers foot rest. Are the pipes cold?
    Yes - heater tap is probably siezed, check its operation
    No - your air mixer is faulty, or there is another cause. Either way I can't help there.
    Please do some research and search the site. If you can't find the problem put another post up with what you know and someone might be able to help.
  1. Vx Berlina Grill On My Vt Berlina
    By blwnvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2008, 07:47 PM
  2. VX berlina lip kit
    By SlipStream in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-05-2007, 08:51 AM
  3. Replies: 57
    Last Post: 12-10-2006, 08:47 AM
  4. VX LS1 VX Berlina
    By OLS108 in forum VT - VX - VU - WH - V2
    Last Post: 09-02-2006, 02:48 PM
  5. Vs Berlina
    By drawbridge@kol.co.nz in forum Electrical Wiring / Questions
    Last Post: 30-08-2005, 05:59 PM
