Results 1 to 10 of 10
Thread: Electic window bulb
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Question Electic window bulb
    just wondering does anyone know how to change the bulb on the vs electric windows its the button u press for the window to go down the lil circle susposed to be green, anyone know what bulb and how to get to it and change it?
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    anyone????
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd hazard a guess and say it's the same tiny bulb that goes behind the A/C button. Mine blew and I used one I unsoldered from a radio but I've since found they are available over the counter at Holdens. I'd go to Holdens and look at their screen which displays the bulb and switch and figure out how to remove. Sorry I cannot be of more help.
    VRII Acclaim
    Jul 2005
    Are you talking about the one in the centre console or the door itself?
    I havent had to pull apart the ones in the door itself, but I assume they are the same design as the centre console. The centre console goes like this -
    The are small little bulbs that are soldered in. To disassemble the switch you need a soldering iron and a lot of patients. It is fiddly and all sort of clips together. It can be done. Your easiest option though is just to replace the switch. If you have a soldering iron and want to give bulb replacement a go - by all means - youre problem then is chasing up the right bulb - holden might, or repco? If not, just go to the wreckers or watch ebay, remove the switch, disconnect the connector and youre good to go.
    Maybe try tightening the connector, just to make sure its not just a loose connection. Long shot, but worth a try.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    oh ok cus i got a whole new switch yesterday for my passanger cus it wasnt working now its got a green light and my driver side one has a yellow light lol
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    I thought the VS power window switches on the center console had 3mm green leds in them? I know my old one did when I pulled it appart.
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    The ones i've half installed are green
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    so would the auto lecky just be able to puta new green bulb or led in whatever it is, or do i have to get a whole new unit for it?
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    You could change it over... im sure an auto electricion could, but I would go it myself.
    Current Issue(s)
    N/A
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    oh ok well i gotta take it there anyway they'l prob do it for free for me there good family friends so they look after us
  1. Blown Bulb indication
    By ivaninoz in forum Electrical Wiring / Questions
    Last Post: 17-09-2007, 09:28 PM
  2. bulb holders
    By ad45 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-01-2007, 08:34 PM
  3. where can i get red BRAKE bulb lights?
    By plAythiNG in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-10-2006, 11:24 PM
  4. headlight bulb question
    By VTPREDATOR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-02-2006, 06:26 PM
  5. light bulb for speedo
    By fergi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-11-2004, 04:57 PM
