Hi there people, could someone please tell me how to remove the washer bottle from my clubsport. Want to clean the shit out of the bottom of it as it takes so long before i get any water thru on to the windscreen, thats if i get any at all. Thanks Fred 96.
surely there are just some screws or small bolts holding it in , probably from underneath if its like the V6 bottle ? there's also a plug for the pump wiring that u need to pull off.
Most Commodores have three phillips head screws that you undo and just dissconnect the water line and washer motor wires (2Xwires but 1Xplug), it's probably not your washer bottle though it more than likely your washer jets on your bonnet.
just use a hair pin or a needle and make sure nothing is blocking the jet and if that doesn't work pull them out of your bonnet theres 2 little clips on the bak of them(under the bonnet) and give them a blow out with some compressed air.
Usually works for me!
