Results 1 to 11 of 11
Thread: knock, knock!
    Jan 2008
    Default knock, knock!
    Hey guys,
    Was just wondering what part is bad when the engine knocks only when accelerating / pulling the throttle cable
    theres no sign of the knock while idling.
    On cold start, it also seems to make a weird rattle / unbalanced type noise for a second or two, then again idles fine.
    Any help will be appreciated, i will try and get a recording of the sound when i get home.
    Thanks
    Simone
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Maybe a timing chain, harmonic balancer, bottom end could be a few things.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like an exhaust manifold gasket leaking or a cracked exhaust manifold to me. The noise will be most apparent when accelerating whilst barely discernable at idle.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    Jan 2008
    i've uploaded a vid to youtube
    YouTube - buick 3800 knock / rattle
    Had a muck around with the car this arvo.
    Seems to only make this noise when in park or neutral. I put the car in drive, with hand brake, and brake on, pulled throttle and engine made no noise...
    Also had a look at harmonic balancer, looks too be intact and good condition.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The rattle in the audio seems about half engine speed and definitely metallic....try removing the serpentine belt just to make sure it's not one of the pulleys - run it for no more than 10 seconds. If the noise is still there with the belt removed try to wobble the harmonic balancer side to side (engine off)...any movement will point to a buggered harmonic balancer. If none of these then it may be getting expensive but keep your fingers crossed. Any other symptoms or has any work been carried out on the engine in the last 3 months?
    Jan 2008
    just removed belt, still happens with it off - that sucks!
    harmonic balancer seems to have no play at all.
    It has had a new alternator put on, but other than that, i'm not sure, as i've just recently bought it.
    Is it at all weird that it only happens in neutral & park??
    vt s s1
    Mar 2009
    H1GHROLLR's Avatar
    H1GHROLLR is offline CHEMICALLY SUPERCHARGED
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    gsxrdan's Avatar
    gsxrdan is offline Has this got a turbo?!
    93 VP Excec; 95 II VR Equipe; 99 VT Exec
    Dec 2008
    adelaide, southish
    harmonic balancer - mine is rooted too, noise is almost gone while driving, but pull up and idle and she sounds like bottom end bearing are gone; but then i see a great hunk of rubber hanging off the harmonic balancer and seems pretty obvious we found the problem!
  1. Knock in my V8
    By road warrior in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-09-2008, 01:04 AM
  2. HELP.... Top end knock!!
    By bigwang in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2006, 06:42 PM
  3. knock knock, whos there?
    By blunt in forum Jokes/Humour
    Last Post: 03-11-2005, 06:03 PM
  4. knock knock bloody knock
    By petesvns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2005, 12:39 PM
  5. Knock
    By .::Crocodile Hunter::. in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-01-2004, 11:50 PM
