Results 1 to 5 of 5
Thread: Windscreen washer bottle
    VR 3.8
    Apr 2005
    Exclamation Windscreen washer bottle
    Hi
    Does anyone know where I can get a new rubber grommet for my vr/vs commodore windscreen washer water bottle?
    I bought the bottle and motor new from Holden, but guess what the little rubber seal that stops it leaking around the motor are no longer available from Holden.
    Smart and helpful
    Tried the vn/vp one for the bottle on top of the strut tower (which strange enough is still available NEW from Holden) but it seems to be too large.
    Thanks for any help.
    Mark
    VR Equipe II
    Mar 2008
    QLD
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    what shape is the seal? maybe try a wrecker if the seal can be removed without damaging it, or a bearing/seals place.
    thats an interesting one, ive never had to replace that seal, will silicone work? or can you cut yourself a cork gasket?
    VR 3.8
    Apr 2005
    It is a tight fit around the pickup shaft of the pump motor and it sinks about a inch into the bottle. the original had a filter on the bottom of it.
    5 speed VR's Avatar
    5 speed VR is offline Green Machine
    Vr V6 Exc 5 spd
    Apr 2006
    Sunny Coast QLD
    A simple fix is put silicon around the opening in the bottle then put the motor in before it goes hard then let it set
    When i grow up... i want to be young again
  1. 96 HSV Clubsport windscreen washer bottle?
    By Fred 96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2009, 10:27 PM
  2. WTB. vr vs washer bottle.
    By Haydz in forum Swap / Wanted to Buy / Trade
    Last Post: 15-10-2008, 03:47 PM
  3. Washer Bottle
    By ducatis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-12-2006, 10:46 AM
  4. Changing Radiator Overflow Bottle to a Washer bottle
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2006, 02:12 PM
  5. law with window washer bottle
    By 94vrexec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2006, 05:56 PM
