Results 1 to 3 of 3
Thread: vs fusable link wiring
    vs equip
    Feb 2009
    Default vs fusable link wiring
    i have just replaced the wire from the alt. to the battery and feed to the fusable links. the insulation at the fusable link was melted. i had to replace the fusable link holder as well as all the plastic around the main feed was burnt and melted. is this a common problem?
    i put a tong meter on the feed to the fusable link. it was drawing 15amps with just the engine running. with everything turned on (high beam head lights, demister, engine cooling fan,air con fan etc) i was getting 80 amps. is this normal, as the bolt in fuse is only rated to 60 amps.
    thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Unless someone else replies I'll check my setup tomorrow when it's light and post what I find - but I thought there were 2 fusible links (inline). The wiring diagram suggest one brown inline fusible link plus an unfused wire running to the engine bay fusebox containing the fusible links. When you measured the amp draw did you check to see if the connections were hot?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Checked mine today and found only the one fusible link next to the fuse box...however I also found a separate feed to the relay block (heavy red cables) but due to the way they are encased I couldn't figure out where they ran.
  1. VB-VL link pin kit for a VR?
    By stocky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2008, 01:39 PM
  2. New fusable link from fuse box
    By weblst in forum Electrical Wiring / Questions
    Last Post: 24-10-2008, 10:23 PM
  3. link pin kit
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2008, 03:51 PM
  4. HELP: Link Pin Kit WHERE???
    By calais_304 in forum The Pub
    Last Post: 28-02-2007, 06:36 PM
  5. Link
    By hindred in forum Site Feedback / Site Problems
    Last Post: 25-01-2004, 12:03 PM
