Results 1 to 17 of 17
Thread: gear slipping.what is it?
    vr wagon, vx executive
    Jan 2005
    Default gear slipping.what is it?
    i went around the corner today and then gave it a boot full. it droped back a gear, started to take off then slipped into neutral and reved to 5grand before going back into gear.it all happened with in a couple of seconds. what do you think is the problem? i checked the auto fluid when i got home and its on the full mark.
    betts's Avatar
    betts is offline Double banger
    Built toyota surpa
    Nov 2005
    Just around the corner
    Sounds like your forward clutch is starting to crap itself, not a good sign aye. This happened to my first car, happened occasionally and then started to happen more and more frequently. Eventually it just packed it in and slipped so much that it just wouldnt go any more. From what I have heard this warrants a full gearbox rebuild, if I were you I would definately go and get it checked by a transmission specialist.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    You are most likely up for a new transmission. I have only just had a reconditioned one installed in mine. I hope you have some money saved up because it is not cheap.
    Jan 2005
    how much did you pay for it? when i put it into gear like drive or reverse it does take a coupe of seconds to in gage. but no other problems changing betweeen gears.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd recheck the fluid level and also the colour of the fluid before I committed to a new trans. The delay when engaging D or R is normal...unless the delay is 2 seconds or more. Also your trans may need a service unless it's been done in the last 12 months.
    seraphic06's Avatar
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Quote Originally Posted by minimefx View Post
    That is actually normal and is mentioned in the owners handbook.
    As for the cost, a reconditioned transmission plus labour was $1950 which included a 12 month warranty. If you shop around you may find it a bit cheaper but I really couldn't be bothered. You could also go to a wreckers and get one from there, but you run the risk of purchasing a dog of a unit.
    Whatever you do, get it looked at first. I may just need a service.
    Jan 2005
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Might be time then to add one of the "stop trans slip" products on the market to delay the time when it fails completely. With the price of secondhand cars nowdays it's sometimes cheaper to buy another car than reco the box.
    Jan 2005
    i may have to just drive a bit slower instead of giving it a boot full just ease on the petal.
    betts's Avatar
    Built toyota surpa
    Nov 2005
    I would be babying the transmission as much as possible if you want to delay it dying on you. The more you put it under stress the quicker it will give up the ghost.
    pedrotski's Avatar
    pedrotski is offline Big Stato!!
    95 & 96 VS 5L Statos
    Jan 2008
    Mandurah
    I just lost a high clutch on my statesman. $2460 for a full rebuild. but im getting billet servos and a bigger stall.
    if you just had a service and its doing it, bad luck
    Jan 2005
    my whole car only owes me a third of that. i'm going to get a second hand one and put that in and see how it goes.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Mybe take it to a gearbox place and ask for a quote and get them to test-drive.
    Mate was going to a rebuild then went to a place and the bloke took it for a drive and it ended up to be a solinode (spelling). Cheaper that a rebuild.
    Don`t remember what was wrong with it.
    Just a thought.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Jan 2005
    it slipped again today and i lost speedo when it happened then come good again. does this mean it could just be my speed sensor and not a f#@*ked gearbox?
  15. #15
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Could well be....if the cable to the speed sensor was loose/broken, cornering may put a strain on the cable and makke the ECU think the car has stopped or something along those lines. You'll have to fix that anyway so maybe you're onto something.
    Good Luck.
  16. #16
    Jan 2005
    had a look at the sensor and the plug is all broken and loose. cabletied it up until i can get a new 1 from holden. supercheap and repco dont sell them
  17. #17
    VS_Pete_1's Avatar
    Dec 2007
    Sorry for the broken sensor mate.
    I have learnt something thow.
  1. Slipping Transmission
    By Toms 50th Ani in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-08-2010, 09:29 PM
  2. HELP!!! Slipping 4th gear on Auto
    By yuntaman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2008, 08:42 PM
  3. only Reverse gear slipping on auto
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-09-2008, 01:40 PM
  4. trans slipping
    By controlled chaos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2008, 04:18 PM
  5. slipping box :(
    By incarsolutions in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2008, 09:28 PM
