Results 1 to 7 of 7
Thread: VS S-Pack noise
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Default VS S-Pack noise
    ok sometimes when I turn left or when I steer hard, usually at low speeds, there is a slight flushing noise, as if liquid was moving around somewhere in the front.
    My first thoughts are the power steering rack??
    anyone have any ideas?
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As long as the power steering fluid level is OK there is nothing simple to adjust etc if the problem lies there.
    It could also be water trapped in the airconditioner and unable to escape due to blocked drains or it could be air trapped in the heater element - both make a noise similar to the one you describe......and a lot cheaper to fix.
    Good Luck.
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Well my heating unit doesn't heat up, it does get nice and cool but doesn't heat up...I've been meaning to check the heater tap and all that gear but haven't got around to it...
    1997 VS II - S
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You'll find the heater just needs bleeding of air - do this by turning the heater to maximum, start the engine and undo the bleeder screw mounted on top of the thermostat housing. You may need to repeat this over a few days to remove all the trapped air.
    Good Luck.
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    so you reckon that will get rid of the noise and will enable the heating to 'heat' up?
    1997 VS II - S
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Should do if that's your problem - from the description you've given it should be. Check the link I've given below as it describes your problem and the fix. Good Luck.
    Noise coming from heater vents
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    For those people having the same problem, this is the bleed valve - open it up to let the excess air out, and bleed the system.
    1997 VS II - S
  1. vs series 2 coil pack?? any coil pack will do????
    By steak000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2008, 07:52 PM
  2. my vn s pack!!!
    By guilty in forum VN - VP - VG - VQ
    Last Post: 13-10-2008, 03:49 PM
  3. how do you tell from VX -S pack?
    By webwombat in forum General
    Last Post: 26-04-2006, 10:36 PM
  4. Replies: 3
    Last Post: 09-09-2005, 11:11 PM
  5. Replacing Series I Coil Pack with Series II Coil Pack.
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 10:04 AM
