Results 1 to 7 of 7
Thread: What does one need to view error codes from the car computer?
    VS3 Commodore Ute
    Dec 2008
    Default What does one need to view error codes from the car computer?
    G'day
    What equipment do I need to connect to my car's computer?
    I have a '99 VS 3 Commodore Ute and would like to see what codes are being returned, as I'm having a problem with the engine dying while I'm driving it. So want to see if its saying anything about the CAS.
    I take it I'd need a laptop and a data cable (what sort of cable? serial? usb? propietary?).
    Thanks
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you can just use a paperclip to get error codes but if you actually want to monitor ecu data with a laptop you need an aldl cable which are easy to make you need the 2 trans 8192 baud aldl cable.they work with either laptop with serial port or a usb to serial cable .the plans are on the net if you cant find it ill add an attachment of a schematic
    VS3 Commodore Ute
    Dec 2008
    whereabouts on a vs3 is the computer port? You said I can use a paper clip, is there a built in lcd that'll show codes?
    I'm just after diag/error codes so I can look em up to see if it will explain the problem I'm having.
    thanks
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    в∞ѕтεכ √&
    Jul 2008
    NZ
    heres a schematic if you want to monitor whats going on with a laptop.there has been debate over wether the diode goes that way round or the other way so if it doesnt work reverse the diode
    Attached Thumbnails Attached Thumbnails What does one need to view error codes from the car computer?-scan3.jpg
    VS3 Commodore Ute
    Dec 2008
    thanks mate but i have nfi on electronics, electrical wiring. So I'd need to purchase a cable if I ever need one.
    Where's the computer port? Is there a built in screen for me to read codes?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    read the thread vn6pwr provided a link to above it explains everything you need to count the flashes on the check engine light to get the codes when you have the paper clip in the plug under the steering wheel
  1. VY trouble codes/error codes. NEED HELP!!
    By GILLO in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2009, 04:04 PM
  2. Computer Error Codes
    By pcp20us in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2008, 06:26 PM
  3. error codes
    By rawsonn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-09-2008, 08:03 PM
  4. Error codes on Vs
    By PorterVs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2008, 08:10 PM
  5. Computer error codes.
    By Bz Kn33z in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2007, 07:15 PM
