Results 1 to 9 of 9
Thread: vr berlina bcm?????
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    Default vr berlina bcm?????
    Hey folks,
    just wondering my brothers car is a vr berlina -- a while ago he was having problems with the door locks sometimes working with the key remote and sometimes not. at first we thought it was a dodgy key as his key was in a few pieces so he said he went to a locksmith god knows why.
    he said the locksmith got the code from his vin number and coded the key and remote.
    currently the key works the ignition
    when u press the button the indicator lights flash but dont know if it actually immobilises the car as u can still start with the key after doing this is this normal????????
    i managed to find the BCM under the steering column - is this a likely cause of fault went to holden as i was under the assumption the key was coded wrong or not coded - they reckon if it works the car the key and remote is fine they said check the BCM out .........
    any ideas if this is where i should check - and its all 4 door locks now not jus and intermittant 1 or 2 - checked the fuses under the steering column they are all fine
    \cheers
    Ben
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    If the key makes the lights flash etc, then the key is fine and coded correctly.
    Do all doors open when you use the key in the passengers door? if not, which ones?
    The BCM should control the doors, but there is more likely something else going on
    When you lock the car with the remote, does the "security" light start flashing?
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Oh and the key will start the car even after the immobiliser is armed.
    Notice the small bump on the keyhead, and the metal prongs around the ignition barrel? These communicate and disable the immobiliser.
    Cheers,
    OzJD
    Current Issue(s)
    N/A
    May 2006
    Perth, Western Aust
    ah ok - umm i did actually notice the doors were weird but i dont have much to go on as my vp is sooooo custom now nothing is standard lol
    when u turn the key only the drivers goes up but theres no - umm like actuator noise normally u hear a click or something and the passengers one should pop up i think but no......
    just the drivers goes up with key...
    when i pull any of the other door locks up i dont hear any noise there either and they dont affect any of the other doors
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    May 2006
    Perth, Western Aust
    hmm ok - pretend im dumb lol - which i am for vr / vs lol - i thought the BCM controlled all doors and windows and stuff - didnt think they had a TDM like vp's do (maybe they do lol)
    any ideas on location - and please dont say same as VP lol under the dash in the centre
    May 2006
    Perth, Western Aust
    if i dont have any luck ill just put 12v to the door actuators on the weekend and test them - then guess ill be tracing wires
    Chirpstr's Avatar
    Sep 2007
    May 2006
    Perth, Western Aust
    hmmm thought ud say something funny like that
  1. MY VX Berlina
    By VicVXBerlina in forum VT - VX - VU - WH - V2
    Last Post: 26-06-2011, 05:21 PM
  2. N0T HIZ 1jz VR Berlina
    By N0T-HIZ in forum VR - VS
    Last Post: 22-11-2008, 10:37 PM
  3. Vx Berlina Grill On My Vt Berlina
    By blwnvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2008, 07:47 PM
  4. Replies: 57
    Last Post: 12-10-2006, 08:47 AM
  5. First Car: VR Berlina SII -12/94
    By KingDiamond in forum VR - VS
    Last Post: 21-07-2006, 08:37 PM
