Results 1 to 7 of 7
Thread: Power window problem
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    Default Power window problem
    I have a Executive.....and a Calais (No engine or gear box)........
    they are both VR's.....
    My Problem is....i dont know what i have to pull out of the Calais and put into the executive to make the power windows work??
    like i want to transfer the power windows from the Calais to the Executive.....
    what do i need?....
    like wiring loom?....or harness?...or......? anything like that?
    or......will it plug into somewhere.....?
    im not to sure....and the "How-To" section didnt really tell me
    thanks guys
    Its a Series 2 by the way
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Depends on your model... some execs have the complete wiring, some have just part of it.
    Check if the both sides of where you put the power window fuse has contacts.
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    I'm pretty sure someone said it depends on if you have IRS or not.
    Current Issue(s)
    N/A
    Feb 2009
    Exclamation
    ok so i just checked and it only has one side of where you put the fuse.....so what does that mean?....what do i have to change in the car???
    thanks
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    New Fuse connector and fuse, Higher level BCM OR a power window module from a VN/P (if you want the auto wind function for the drivers door), Some door wiring looms, The wiring for the center console. That's all I can think of.
    A circuit breaker would come in handy, too.
    Current Issue(s)
    N/A
    Feb 2009
    thanks buddy......do you know how much the BCM would be?....and i thought series 2 BCM could handle power windows....?
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    If it's an exec, it should be a "LOW" BCM which dosn't do windows.
    Personally i'm in the middle of doing my windows, and I don't have any plans in changing the BCM or getting a power window module as all it controls is auto-up and auto-down functions
    Then again, I'm not even using a loom, making my own lol
    I can confirm that the Series II has a low BCM as we were looking at it yesterday (my wifes has Series II)
    Current Issue(s)
    N/A
  1. power window problem
    By VNexecutive in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2010, 12:57 AM
  2. Power window problem...
    By Cyph3r in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-02-2009, 03:11 PM
  3. VT power window problem
    By joebloggs in forum Electrical Wiring / Questions
    Last Post: 21-02-2008, 07:34 PM
  4. VY Power Window problem?? - HELP!!
    By Fester1548 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-12-2006, 09:17 AM
  5. help! power window problem!
    By skarekrow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2004, 06:22 PM
