Results 1 to 3 of 3
Thread: Vr and VS Torque Converters and flex plates
    VS Commodore
    Feb 2009
    Default Vr and VS Torque Converters and flex plates
    Iv just put a vs auto transmission into a vr, everything bolts up fine and i changed that back housing thing for the speed sensor.. problem is i also replaced the vr torque converter with the vs one thinking they would be the same, after gettin it sittin up there i find out with the torque converter pushed rightin there is about a 13mm gap between it and the flex plate. Is something different or is it how its ment to sit?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I cannot tell you for sure if the converters are the same but I can say that sometimes it takes quite some time to fully seat the converter to the transmission. Keep trying!!! Hopefully this is your problem.
    VS Commodore
    Feb 2009
    i bolted up the torque converter afterwords put it in with the gearbox so that wasn't much of a problem, the box is flush with the motor just there is play in the torque converter
  1. flex plate
    By Grazman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2008, 08:05 PM
  2. 8 Bolt flywheel/flex plate torque settings?
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-09-2007, 11:23 AM
  3. Flex Plate???
    By weedo_86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2006, 05:28 PM
  4. Hi-Stall Torque Converters Help.
    By pro_gmh in forum Straight 6 Development And Modification
    Last Post: 10-11-2005, 07:24 PM
  5. Anybody in Brissie got Ecotec Torque Plates
    By portercg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2005, 11:58 PM
