Results 1 to 10 of 10
Thread: Vs running like its gunna stall
    VS Executive
    Nov 2008
    Default Vs running like its gunna stall
    hi guys, hope someone can help me. Today while driving home my vs suddenly started running very rough and shaked like it was going to stall, i pulled over and put it in park, it idled a bit smoother but not much. When i put it back in drive it got worse again, i drove it home but had bugger all power or acceleration it wouldnt do 80km and was shakeing badly. any help would be appreciated
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    if its idling smooth, check coils and sparks.
    If it's still missing when smooth, check fuel and spark
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Welcome to the forum. As posted above, first check the electrical side - maybe a plug lead has fallen off the spark plug causing it to miss. Try running the engine tonight in the dark with the bonnet up and look for any sparks caused by leads shorting out.
    Maybe more info is also needed like how many Kms or any recent work done on the car. More info means more clues!
    VS Executive
    Nov 2008
    thanks for quick response. I checked plugs, leads and coil packs this arvo all seem ok .plugs and leads about 8 months old only done 2000km , have recently replaced CAS and RH oxy sensor and fuel pump, exhaust only 3 months old. i just went to check for spark short in the dark, all looked good engine was running excellent so i went for a short drive it run like norm (good pick up, nice and smooth) i came home left it running went to go again and it got very rough again sounds like a vw and shakes very badly when in gear, when in park not good but not AS bad as in gear. the engine has done 235000km
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Did you look at the engine for electrical leakage after you went for a drive and it ran rough again? - any leakage? May also be a coil or the DFI module - there are test procedures in the Gregorys manual or on this forum (previous threads)
    VS Executive
    Nov 2008
    thanks no there were no elec leaks, my wife took it to mec today and he said head gasket is gone but i dont think thats the only issue, he said $1500 to fix, gonna cheak on reco price, anyone know how much i should be lookin at - or the best way to go(fix or replace)
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    $1,500 for a head gasket job - ouch.
    The head gasket (if not losing coolant) should not be an intermittant engine shake issue)
    The running badly from time to time is most probably and electrical issue with the DFI/coils/ECU or on of there connections.
    Also worth going over the earths and give some of the wiring a bit of a wiggle to see if the engine runs poorly or not.
    and 3 Dangerous non ABS VN's
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You could get another motor from a wrecker for $500 up with a warranty....throw some leak sealer in the coolant and hope it seals,....reco the complete engine $3000....sell your car and buy another at about $3500 for a good one less what you get for yours.
    Good Luck.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    do you know how they came to the conclusion of the head gasket being bung did they check for combustion gas in the radiator with a headcheck kit or was it just a guess.ide be looking at the cas again being that its sounds like it does it when it warms up and also check the coolant temp sensor.any reason why you didnt replace both o2 sensors at once maybe the other has got a bit lazy.
    VS Executive
    Nov 2008
    the engine has been losin coolant prolly1/4 a litre a fortnight. only replaced rh oxy cenc cos i got code 13 replaced it and got no other fault codes,app mec said head cos coolant was boiling and had to keep adding while the car was running
  1. this is were im gunna stick some gauges - help/opinions needed!!!
    By PSYKO PHOENIX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2009, 12:57 PM
  2. OOPS im gunna be a dad again.
    By adam69 in forum The Pub
    Last Post: 03-08-2008, 06:21 PM
  3. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  4. How much a service gunna cost me?
    By VSSPak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-05-2006, 03:11 PM
  5. Gunna get a 3G mobile....
    By frenzal_tom in forum The Pub
    Last Post: 21-04-2006, 08:13 PM
