Results 1 to 10 of 10
Thread: Comfort Shocks
    INDACLUB's Avatar
    INDACLUB is offline Black VX SS
    Black VX SS, White VQ 5ltr
    Apr 2008
    Default Comfort Shocks
    Hi guys, my dad just bought a VS Series 3 Ute which is lowered on king springs all round. Not sure what king springs are on it. The ride is back breaking, just wanted to know what are some better comfort shocks he could use. Hes not after performance handling just a bit easier on the back.
    Thanks
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Just put the stock suspension in then.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    pretty much you get to a height where no matter what you do, your ride is going to be shit
    just replace it with shortened shocks i guess and if you really wanted to you could get shorter bumpstops (or cut em, your choice)
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    personally, i'd go fe2 springs (softer) and use a stiffer shock, should limit the amount of bounce in the extreme upper n lower limits whilst still providing a good comfort range.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    I know for fact that if its lowered it will be sitting on bump stops at the rear.
    my mate has a vs III ute and its on SL's and there is no gap in the bump stop. maybe look at shorter one's?
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    ive got monroe gt sport shocks and they are pretty good, a lil bit expensive but worth it. i hardly feel many bumps, mines on sssl's aswell
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
    danja's Avatar
    Jan 2006
    Quote Originally Posted by padrickz88 View Post
    Quote Originally Posted by ephect View Post
    He said he's not after performance? Why would you put shortened shocks or stiff springs in?
    Just put the stock boat suspension in, it won't fly around corners, but it will be gentle on his old man's back.
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    Quote Originally Posted by danja View Post
    I said shortened shockers because he asked about shockers and if he is low enough for it to be rough, then its low enough for a spring to pop out so why replace a shocker with a stock one when a shortened one would be better for his application?
    Also since he asked about comfortable shockers i thought i would add the point that his probably hitting bump stops which is probably the main reason his ride is shit, so shortened/cut bump stops would be better for ride comfort....
    Add them two together and it would make a more comfortable ride (what he is trying to achieve)......
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by INDACLUB View Post
    Thanks
    its lowered, and he didnt state that he wanted to change the suspension, he only wanted it to be more comfortable. hence asking for different shockers.
    exactly
    add that and stiffer shocks and it should increase the comfort level.
    danja's Avatar
    Jan 2006
    Fair enough
    I still reckon barge suspension for comfort though.
  1. [SA] F.S. KYB shocks & Pedder Sports Ryder shocks
    By GTP 85 in forum Parts And Other Items For Sale
    Last Post: 16-03-2009, 04:43 PM
  2. What shocks for 5l?
    By Uber_Matt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2008, 07:40 PM
  3. shocks
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2008, 11:20 AM
  4. FE2 Shocks
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2007, 09:27 PM
  5. Shocks
    By Leigh Druett in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2005, 08:38 PM
