Results 1 to 6 of 6
Thread: vr 5.0 starts then stalls
    Haydz's Avatar
    Haydz is online now Fasten your seatbelts
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    Default vr 5.0 starts then stalls
    hey guys. been having a problem with my vr
    it wont start. it cranks for ages but wont start.
    but if i remove the lead between the coil and the distributor it will start run for about 30 secs or so. then die.
    what should i be looking for?
    i know its either a fuel or ignition issue. just not quite sure how to check and what to check.
    pedrotski's Avatar
    pedrotski is offline Big Stato!!
    95 & 96 VS 5L Statos
    Jan 2008
    Mandurah
    Quote Originally Posted by Haydz View Post
    clean the terminals on the ignition modual located avobe the air box. see if that helps.
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    could be ya coil on the way out - they get hell munted in there usual location
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Haydz, i dont quiet get what you saud there. If you disonnect the lead between the coil and distributor how does the car work at all, it would have zero spark.
    Reaper
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    sorry guys.
    i mean if i disconnect then re connect the lead between the coil and distributor. it will start again.
    but only for 30 seconds or so. then it will stall no matter what. even if i try holding the revs up.
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    dont worry guys. must have been some water stuck where it shouldnt have been.
    as i pulled out the compressor and gave all the electricals a good blowing. and know she works.
    no worries. thanks though guys.
  1. Starts then stalls
    By VNSV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2009, 09:58 PM
  2. Toyota van starts, idles bad then stalls
    By VNexecutive in forum The Pub
    Last Post: 04-02-2008, 09:47 PM
  3. Car starts but stalls - fuel pump?
    By MasterOfReality in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2007, 08:52 AM
  4. VT, V6 stalls, then starts straight away.
    By Tonechiller in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-10-2007, 04:17 PM
  5. VN CALAIS starts then stalls
    By DESINC in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-09-2006, 12:58 PM
