Results 1 to 4 of 4
Thread: Getting rid of the engine fan and running thermo fans on a 5L
    pedrotski's Avatar
    pedrotski is offline Big Stato!!
    95 & 96 VS 5L Statos
    Jan 2008
    Mandurah
    Default Getting rid of the engine fan and running thermo fans on a 5L
    Hey guys.
    I have an engine fan on the car, but i was wondering if it would be better to use thermo fans?
    The tempreature on the guage is never above 1/4 even with the air con on full blast on a 30c day, but i was wondering if it would be safe to remove the engine fan and replace with thermos to save some strain on the engine.
    Thanks
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    The only advantage thermo fans would be, if your temps are already under control, is there would be no excessive wind noise like is generated from the standard fan.
    When you say that you want to take load of the engine, the standard clutch fan is designed to limit the amount of load on the engine. Remember that the thermo fans do require a lot of power to drive them, thus loading the alternator and in turn the engine.
    muttley383
    pedrotski's Avatar
    Jan 2008
    Mandurah
    Quote Originally Posted by muttley383 View Post
    ill just keep the $250 bucks
    thanks for that.
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    If you really wanna blow $250 on nothing, bring it to me and ill renew your fuses
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
  1. EF thermo fans onto VN V6
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2009, 04:35 AM
  2. WTB EL to AU Thermo Fans
    By Holmez in forum Swap / Wanted to Buy / Trade
    Last Post: 13-11-2008, 05:40 PM
  3. THermo fans
    By dave0103 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2008, 08:48 PM
  4. VT S Pack engine fans keep running after car is turned off.
    By Cashy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2006, 08:24 PM
  5. Thermo Fans
    By bigg_vin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-09-2006, 12:14 PM
