Results 1 to 4 of 4
Thread: VR running problem
    VR Executive
    Mar 2009
    Default VR running problem
    My 1994 VR started running rough, noticed a crack at the back pipe of the left exhaust manifold. That was fine replaced with second hand one. Car still started rough( 5 cyclinders). It does this everytime you start the car after sitting for a long period of time or cool morning air, until the engine heats up and then it runs on all 6. So have changed the leads, spark plugs and put some injector cleaner in petrol. Thought all should be good but NO still running on 5 cyclinders again. Could it be the distributor playing up, sticky lifter or blocked injector or something else? Checked all leads on correct plug sequence heaps of times, not a problem. Can anyone head me in the right direction to fix this it's annoying the crap out me.
    96 VS II Acclaim
    Dec 2007
    Quote Originally Posted by Doddsy18 View Post
    Error codes would be a good starting point.
    XeKToReX's Avatar
    XeKToReX is offline Put it on credit!
    VK SL, VR Exec, VS Stato, VT Clubby #555
    May 2005
    N/E Melbourne, VIC
    check injectors, coil packs etc, its either a fuel or spark problem, as for the exhaust manifold crack, i think every VR i've seen with stock manifolds has a crack there.. very common problem..
    VB SL/E
    Dec 2008
    Have you tried cleaning/checking the PCV valve?
  1. VS Problem - Running Rough / Stalling
    By XTC16 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-10-2007, 09:35 PM
  2. 202 not running right
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-10-2007, 07:22 PM
  3. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  4. 85 VK P/S A/C Gas..... Not running
    By figjamidhVK8t4 in forum Parts And Other Items For Sale
    Last Post: 08-07-2006, 01:09 PM
  5. Vn problem running crappy
    By kasey375 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-02-2005, 06:36 PM
