Results 1 to 3 of 3
Thread: shuddering vs
    VS Vacationer
    Dec 2008
    Default shuddering vs
    hello all,
    i'm just wondering if anyone could shed some light on a problem i've just encountered...
    after swerving a little to get past a car entering a driveway, i got a really bad shuddering sound/feeling from the back of the car- so bad that through the rear vision mirror everything got very blurry/distorted. i stopped, and then took off again, no problems. then, in turning into my driveway, it came on again.
    any ideas as to what the problem might be?
    i hope its nothing too serious- i have to get from wollongong back to penrith tonight.
    cheers,
    plooky
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like the panhard rod on the diff has badly worn rubbers - this rod stops sideways movement of the diff when cornering. Check by pushing the rear of the car side to side as hard as you can and watch to see if the body moves sideways in respect to the wheel.
    It may be OK to drive but be very careful going round corners....so really it's up to you.
    New panhard rubbers or a new rod are not expensive however if let go they can put a lot of strain on the rearend components. Hope it all pans out OK.
    Good Luck.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Hopefully you got there OK, are your rear wheel nuts tight?
    Visit my Facebook page
LinkBacks (?)
  1. 22-03-2009, 06:21 PM
  1. VL shuddering.
    By langer_and_mash in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2008, 06:13 PM
  2. Shuddering on take off
    By inoutinout in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-09-2007, 07:46 AM
  3. shuddering
    By Panama in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2007, 10:38 PM
  4. Shuddering
    By Stretchomatic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2006, 05:11 PM
  5. Shuddering
    By kim_08 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2005, 01:34 PM
