Results 1 to 6 of 6
Thread: How to change VS Bonnet spring?
    VS Maloo Ute
    Mar 2009
    Smile How to change VS Bonnet spring?
    Hi all, how do you change a VS Bonnet spring?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you mean the gas struts that hold the bonnet then you prop the bonnet open with a broomstick, and slide the spring clips off - this releases the ball and socket.
    s1knt is offline Banned
    vt senator
    Dec 2008
    VS Maloo Ute
    Mar 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    There are 2 springs in the lock - the one on the centralising pin and one which does the actual latching - I'd guess it's the latter you refer to?
    VS Maloo Ute
    Mar 2009
    Yes the latching spring, how to replace it.
  1. need help! bonnet latch is broken and cannot open bonnet!
    By boourns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2012, 11:10 AM
  2. Bonnet release cable snapped how do i open the bonnet
    By S-Pac_Sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 09:07 PM
  3. how to change spring in a vy s pac
    By jvys in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-10-2009, 09:49 PM
  4. Tightening bonnet hinge(body end, not bonnet end)
    By NOGEN 3 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-03-2007, 11:28 AM
  5. Oil Change/filter change interval on VTII 6 cyl ?
    By nmldb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-06-2006, 04:26 PM
