Results 1 to 6 of 6
Thread: VR 5L Problem
    vr ute
    Mar 2009
    Default VR 5L Problem
    i have a problem with my ute, starts and runs fine most of the time but after a lil driving and i stop at a roundabout, the lights, etc it starts to miss a bit. once its going again it runs fine until i stop again.
    i know these have problems with the ignition module so i replaced that but it still does it and its got me beat. it seems to be worse when the a/c is running.
    occasionally it wont start either but after trying a few times it'll start up straight away and run fine. it fires but wont keep running.
    any help would be appreciated
    cheers Gilly
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Welcome to the forum.
    The Hall effect sensor inside the distributor also is a problem from what I've read - that tells the ignition module when to "pass the spark along".
    Good Luck.
    VR HSV Clubsport
    Jun 2008
    Hobart,TAS
    Same happened to my clubsport a few months back....turned out to be a coil on the way out.My advice when changing coil,lengthen the wires after you unplug them and mount the coil to the inner strut tower,and leave the old coil in situ if you want,you will see why when you go to change it.....
    Tasmania....Coz 2 heads are better than one...
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    maybe even check your battery terminals if your also having probs starting
    vr ute
    Mar 2009
    its not the battery it cranks fine.
    cheers for the help guys i'll raid some parts off the hilux to see if it helps
    vr ute
    Mar 2009
    stole the coil from my hilux (it runs the same motor ) seems to have fixed it atm, need to take it for a longer drive later on today
  1. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  2. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  3. gas problem
    By kasey375 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-04-2006, 12:32 AM
  4. A/C problem
    By ninja in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-12-2005, 09:05 PM
  5. LSD Problem
    By scbh81 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-12-2005, 08:48 AM
