Results 1 to 18 of 18
Thread: help please!
    WogBoyz's Avatar
    WogBoyz is online now Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Exclamation help please!
    alright everyone well today i noticed this not to good oil leak comming from around the area where my oil filter is
    here is some pics
    the black peice of the left in the 2nd photo is my oil filter, does anyone know where exactly the leak cud be comming from around there? or had this problem b4, it needs to fixed quick too oil is going down rather quickly
    would i be able to fix it myself? or need a mechanic to check it out?
    any help much appreciated
    thanks
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    Mar 2008
    Give it a degrease around the wet area or a wipe down,than start the engine and have a look.Might be the oil pressure switch or the oil filter.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    I'd be guessing at the oil pressure switch thingo.
    and 3 Dangerous non ABS VN's
    vb sle
    Jan 2009
    adelaide
    that oil looks red to me is the power steering pump above that coz oil on the filter looks old ill be checking power steer pump first
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    so shud i change filter n see how it goes or shud i get a pic of the container i got underneath with some of the oil in it?
    Mar 2008
    Like Leigh said does look a bit red,have you checked the power steer fluid?
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    nah man i havnt yet i start work in lyk 10min heres some more pics
    88GreenVN's Avatar
    Jun 2006
    When you say losing oil - engine or steering?
    Mar 2008
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    That really big pulley is the power steering pump. You will probably find that one of the hoses going to that is leaking, most likely the return hose. That is the one with the hose clamp on it. Try tightening it first and see how you go.
    Visit my Facebook page
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    i got dad to look at it, he reakons its a powersteering line leaking, he said my power steering fluid is also a bit down, were gunna book it in to the mechanics first thing 2mro morning
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    id like to thank everyone who helped out here if i knew how to give good rep, id give you all some but i dont so thanks for the help ppl apprecaite it
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    to give rep out, click the little scales next to the post number in the top right hand corner, of each post you want to give rep to, then type away.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    ahhh kk sweet man thanks rep for you! haha
  15. #15
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    oh wait it has only scales for my posts not anyone else's
  16. #16
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    well it turned out to be my power streering pump $247 later and a new reconditioned pump and working all good no leaks now
  17. #17
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    good to hear its sorted, n thanks for posting up the solution
  18. #18
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    hey no worries man, im glad its sorted too
