Results 1 to 7 of 7
Thread: VR V6 strange idle
    VS SS
    Mar 2009
    Default VR V6 strange idle
    Hi all, been a long time reader but this is my first post, have an issue with my VR V6 calais, when on idle it sometimes idles high, sometomes low, when i turn on the a/c the idle goes up to around 1800 rpm, when i take it out of gear (auto) instead of revs rising slightly, they drop! I have changed the IAC with little to no change. Also when i put it into reverse its fine, but when i put it in drive theres a slight delay, other than that it runs perfectly, any advice would be greatly appreciated, thanks.
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    as for the delay in changing to drive, check tranny fluid etc.
    as for the idleing, not sure about the park etc, but I would expect it to go higher for aircon, as the engine has a bit more work to do.
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The delay in selecting Drive is normal if it's no more than 2 seconds (it's mentioned in the owners manual). Idle speed should be the same with air on/off if the IAC is working. Re the idle - did you reset the ECU after IAC installation? - also check you do not have a vacuum leak...hose off or split maybe. And welcome to the forum.
    Good Luck.
    vr berlina
    Oct 2007
    Sunny Coast
    I think it could be an vacum leak. Sounds like a similar promblem that i had recently. Go over all of them, check for cracks, they get really hard from the heat. Mine was at the back of the engine bay, on the elbow for the throttle body
    All GO
    VS SS
    Mar 2009
    gday fellas yes i reset the ecu and did check for vacum leaks, looks to be ok, the trans takes probably between 2-3 seconds to select drive, although the fluid color looks a bit dodgey, kinda browny red, thanks for your help guys.
    vr berlina
    Oct 2007
    Sunny Coast
    hey dude. i talked to a mate who is a auto trans builder and said that it is most likely your stall converter is crapin out, that if is the cars running fine. He suggested to save some coin for a new converter or a bit more for a rebuild. I have got a vr berlina that was rebuilt in 2002, with shift kit, stop valve for 1st to 2nd shift, 2200 stall strong sun gear and other some other stuff and it has done near 300,000km under boost since then and still shifts like a champion every time.
    All GO
    Suzuki Swift GTI
    Dec 2008
    cessnock
    although the fluid color looks a bit dodgey, kinda browny red, thanks for your help guys.[/QUOTE]
    When the fluid is starting to get darker like black its time for a change.
  1. Very very strange!!!!
    By 2greedy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-11-2008, 07:23 AM
  2. battery dying and strange idle speed
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2008, 08:40 PM
  3. Strange, strange problem.
    By Morton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2007, 05:26 AM
  4. Strange
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-11-2005, 03:51 PM
  5. Vn strange idle
    By STYALR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-11-2005, 05:54 PM
Tags for this Thread
