I have just replaced the inlet manifold gaskets in my 5lt and since then everytime i start the car it will run for a couple minutes then the engine light will come on.
I checked for error codes and it is telling me error code 15, I replaced the coolant sensor and it hasn't fixed the problem.
Any comments will be a great help thanks.
if its the coolant temp error, it will have to be related to it. How closely have you looked at the wiring.
Heres some reference materialsoyou can start testing http://www.injectronics.com.au/bulle...ulletin_18.pdf
Fixing Wiring To Coolant Temp Sensor
See how you go it cant be anything too dramatic, will be somthing simple when you find it.
Thanks mate
I will have a good look at the wiring
Still can't find the problem.
Would it be better to pull the inlet manifold off again?
which sensor did you replace the 1 wire one or the 2 wire one for the ecu
Found the problem
It was a broken wire in the conection
told you it would be somthin simple![]()
