Results 1 to 3 of 3
Thread: v6 to v8 conversion
    aphexcloud is offline mech
    vr v6/5.7l wh statesman
    Sep 2008
    Default v6 to v8 conversion
    i know this has probly been asked 100 times before and even more conversions posted on the forum but hey ill ask any way i am going to be putting a 5.0l in my car was just wondering if people could link me a thread on the forums to such a conversion. thanks in advance.
    ps: does any 1 know if there is any difference between the vr-vs 5.0L and vt or is it jus engine cover
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Vt has more grunt as stock its 195kw and the vn/s is only 165kw. The vt also has some internal mods.Not sure extactly but i think its somthing with the rocker setup and somthing in the bottom end.
    As of yet i have yet to see somone write up a how too on a 5ltr conversion, which is a shame cause they get all the info off people here but dont return the favour by doing a nice writeup for others later.
    If you search through the forums you'll find this question asked plenty with plenty of replys to read through which should get you going.
    What engine do you have, the Vt or vn.
    Reaper
    VR Caprice
    Dec 2005
    I've done it and its a good conversion especially if you have a car that is the colour you want and you have done other mods. The VT motor has to be converted back to VR/VS spec because it has the map and sequentual injection. Also the computer for the VT is not usable unless you want to do a lot of wiring mods.
    I would recommend trying to get hold of a wrecked VN/VR/VS and you will get all you need off it.
    Items needed are:
    Instrument panel if you get a VN you will need a VR/VS panel)
    Front Shocks and Springs
    Motor, Harness and ECU
    Ignition module
    Airbox
    Kframe
    Power Steering lines and pump
    Airconditioner Condensor
    Tailshaft
    Radiator
    Air conditioning lines
    There are a few more bits and pieces but that is the main, lots of ppl will tell you you need the V8 brakes you don't as they are the same spec as V6 brakes. But if the V8 you get has a 1" master use it.
    PM me if you want more.
  1. v6 to v8 conversion???
    By silver_bullet in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-09-2008, 10:03 AM
  2. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  3. WTB: Gas Conversion Kit for VN
    By PaRaDoX in forum Swap / Wanted to Buy / Trade
    Last Post: 14-05-2006, 01:45 PM
  4. V8 conversion
    By CHANDLC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2006, 07:42 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
