Results 1 to 6 of 6
Thread: VS Ute - Wipers work on slowest speed only?
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Default VS Ute - Wipers work on slowest speed only?
    Hi all.
    I just purchased a 1995 VS ute, been chasing one for ages and a good condition example for rather cheap just came up. Anyway, that aside. It is in A+ condition all round with the exception of the windscreen wiper setup.
    It only works on the slowest setting?
    Moving the lever to the first stop starts them going slowly as expected but when you move it down to the next stop it does speed up.
    Can anyone point me in the right direction here? What could be the issue?
    My first though was some sort of control module may have gone cactus.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Could be in the switch itself. It works on resistance, the first setting has more resistance than the second that is why they go slow, but maybe the contacts are corroded or dirty and there is too much resistance on the second setting.
    Visit my Facebook page
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Ahhh, ok. Cool. I'll rip it out on the weekend and see what I can do about giving it a once over. I was thinking it was just a multi-point switch so didn't even consider that..
    Cheers. If it turns out that it is NOT the switch (which shall be proven only by buying a new one) any other ideas?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The wiper motor is a 2 speed motor and there should be no resistance in the switch (at least not from the wiring diagram and wiper motor description) so the switch is simply a multi-position switch. Mine has exactly the same problem although I can get hi speed if I force and hold the arm down so I'd say it's a mechanical problem with the switch...and probably fixable with a bit of adjustment.
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Quote Originally Posted by hako View Post
    Hmmm..... That makes more sense to me. However what really gets me is that the intermittent position does work either? Place it in intermittent (which I was referring to as "position 1", sorry for the confusion) and it just starts up straight at a slow, constant speed...
    VY SV8 HBD---mmmm LS1
    Simon Champion! On The Volley Champion! Shootin Hoops Champion! Batting Champ Champion!
    Dec 2005
    Western Suburbs
    your wiper motor is on its way out happened to me did you also take ur wipers off change them etc mine seemed to stuff up after i took them off
  1. Wipers don't want to work
    By NAILS in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-11-2008, 07:48 AM
  2. windscreen wipers speed
    By vsiicalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2008, 08:36 PM
  3. vn 4 speed fan not work
    By bbau78 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-01-2007, 08:17 AM
  4. windscreen wipers... occasionally work
    By PerceptionTwin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2005, 10:49 PM
  5. HELP! Windscreen wipers on level 1 wont work!
    By built4girls in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-03-2005, 03:21 PM
