hey guys.
i currently have a vr caprice 5.0
and being a p plater in nsw. may be facing having slot a v6 in her if i cant get an exemption
just wondering. is this a hard excercise?
if i were to buy a v6 motor and tranny inc computers etc from a vs. ecotec.
uhmm anything else i would have to change?
and also getting it registered with the 3.8 anyone know the course of action?
does it have to go for another blue slip with the new motor.
thanks alot guys
wooow wooow, Dont do that. u only want to go up, not down.
why not look for a 6 banger caprice??
dont worry, il start a ride thread soon.
because i allready bought the 5 litre.
and i would then be able to trick up the 5 litre ready to put back in
and considering the price of a decent v6 and auto is about 4-500 bucks including everything.
it would make it not too bad. as i can do all the work myself. just might need to hire a hoist for a day or two.
and this is only if i cant get an exemption to drive the 5 litre.
ohhh i get you now.
Why not buy a lil nugget car to run around in?
shouldn't be that hard, probably need a donar VR. depends really on how muchlonger you are on your P's as to how much you do, The AC piping is very different so if you do the conversion and could live without AC it make it easier and cheaper, you would need radiator and Kframe ECU and engine harness.
It makes sense to do what you say as you can trick the V8 up and get things ready for it to go back when you do the 6 record everything you take or alter for the return of the 8.
I wouldnt bother with suspension alterations and such just would motor gearbox tailshaft Etc.
dude.... buy another car. If your on your p's man why would u buy a 8 to start with. anyway good luck man.
big work but it would give u great experience in engine changovers
I would just spend the money on another car to run around in, a lot of work just to satisfy a rule. While you are driving the other car trick the stato up. You will probably sell the other car for about the same as you bought it for anyway so no loss. How long have you got to go?
well thanks to all for your input. turns out i didnt have to do anything. just got an exemption to drive the 8![]()
