Results 1 to 4 of 4
Thread: VS S Pack Ute - LSD Not working?
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Default VS S Pack Ute - LSD Not working?
    Ok I have an S pack ute and the LSD doesn't seem to be working? The diff cover has the appropriate tag etc.
    What can cause this?
    I am aware of only the following possibilities:
    - old, crappy oil in diff fouling it
    - clutch packs too worn
    Are there any other possibilities and what potential fixes are there?
    Thanks.
    VR Caprice
    Dec 2005
    Its quite common for the LSD centre to crack and send it to single spinner. ift the back of the car up and turn 1 wheel if the other side turns the same way at the same speed your LSD is good. It may need a good service I have been quoted $650 for a full rebuild her at Taree.
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    I was told it was just a matter of opening it up and putting new cones in the centre. Can anyone confirm this?
    VR Caprice
    Dec 2005
    Its a bit more than that as if you dont shim them properly you can do heaps of damage, you also need to remove the axles so you need a slide hammer. I would say if you havnt done this before oe dont have a really good understanding of the process get the pros to do it.
    There may be more damage than the cones.
  1. [NSW] vt s pack GTO
    By bullet05 in forum Vehicles For Sale
    Last Post: 13-12-2008, 06:09 PM
  2. vs series 2 coil pack?? any coil pack will do????
    By steak000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2008, 07:52 PM
  3. my VN s pack
    By VN_S_ADEL in forum VN - VP - VG - VQ
    Last Post: 28-10-2007, 07:01 PM
  4. Blaupunkt 6 stacker Antenna Buttons not working in S Pack
    By Crintonn in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-03-2006, 06:42 PM
  5. Replacing Series I Coil Pack with Series II Coil Pack.
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 10:04 AM
