Results 1 to 5 of 5
Thread: A/C and A/C light on button no working.. vs 97
    vs II S ute 1997
    Mar 2009
    Default A/C and A/C light on button no working.. vs 97
    hi guys
    in my vs ute the ac doesnt appear to be working? and the light does not come on when the button is pressed... please help
    does this mean it needs regassing or is there an electrical fault there some were stopping the ac unit kicking in??
    cheers guys
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It could be that you are low on gas or maybe you have a faulty low pressure switch. It could something else also, so best thing to do is get it checked out by aircon specialist.
    MY RIDE
    VU SS s2
    Apr 2008
    good bet he is right there, if the gas pressure is too low it wont allow the compressor too kick in. this is uaually the cause 90% of the time.
    1996 VS Ute V6 Executive Series 1
    Feb 2009
    i recently just had the same problem
    the solution was the liquid line had a small split in it, which had been worn over time due to a mesh that was placed infront of the radiator i think (thats what the mechanic said)
    dunno if this helps but it cost me around 350 to get the line fixed and the A/C regassed through a local bloke
    like i dunno if this helps but it might a bit
    VS 5LT STATESMAN
    Sep 2008
    Hi previous posters are correct low gas will stop a/c from working but with your case i would say a blown fuse or crook switch as they are first in line you can have a non functioning compressor and still have the light on the switch i would look there first. Hope this helps
    Jon
  1. aircon button not working
    By vs hay hauler in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2008, 01:10 PM
  2. PWR ECO Button... doesn't light up
    By DzRBenson in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2008, 09:52 PM
  3. Mode button light?
    By VTSSDUDE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-11-2005, 04:33 PM
  4. Air Condition Button light not working
    By VS1Tonner in forum Electrical Wiring / Questions
    Last Post: 23-09-2005, 01:10 PM
  5. replace the light in the power button
    By cuckoo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-08-2005, 09:55 PM
