Results 1 to 14 of 14
Thread: electrical problem?
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Default electrical problem?
    ok my VS is being weired lol. when it been sitting for a while and i start it and turn lights on (night time) the headlight's dim up and down and so does all interior lights...not enough to go dark but just flickers..i guess u could say that lol.
    im thinking alternator or regulator? as within about 3 min it goes back to normal
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    old battery?
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Just grab a multimeter, and check it (they cost less than $10 if you dont have one already)
    Current Issue(s)
    N/A
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like the brushes in the alternator may be worn down so far they are only just touching the slip rings - an easy check by removing the brush holder at the rear of the alt. (2 screws). If not this I'd be looking at switches, relays and fuses.....move each of these to see if it causes dimming. I'd agree with the above posts as well.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    cheers guys
    got battery checked and it reading 492 cca and it a 520 cca battery so nothing wrong with it there
    i check the brushes and relays tomorrow
    cheers
    Vr Executive 3.8
    Dec 2008
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Yeah, what are you running that didn't come with the car? Carputer? Navigational Devices? Sound System?
    Current Issue(s)
    N/A
    Changa is offline Alex Short
    VS Executive
    Jan 2009
    Hervey Bay, Queensland
    My VS's lighting and head lights dim on start up, but I imagine this is because the starter motor draws alot of power from the battery temporarily cutting back the power for other accessories, I think its fairly normal.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    ok update..
    battery is ok (got it tested)
    alternator output is 14.6 volts (when it diming up and down)
    its liek its arching somewhere and makeing the lights, intrerior light, dash lights dim/spike (if that makes sence)..it only does it if it has been sitting (un started) for more then 4 hours...then it come good when u drive....but does look funny when u driveing and light are diming up and down (and interior lol)
    seems liek it getting worse to
    is there a main wire running somewhere that can cause this? me dad is an electrition and is handy with automotive sides of things but if we/he cant find anything then ill bite teh bullet and take it in it a auto place
    yes i have a sterio in teh car but it aint on when i start it
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check all connections to the relay and fuse block under the bonnet....maybe one of the fusible links is loose or corroded. Check all relays to see if they get hot during operation also tap them gently.
    14.6V is too high for the alternator - should be 14.2V maximum...maybe the regulator needs replacing or the multimeter you're using is reading wrong?
    Try turning the lights on etc and then with the engine running wiggle/wobble/gently pull all wiring basically everywhere till hopefully the fault repeats.
    Before all this happened did you do any electrical work on the car?
    Last thought - check the ignition switch wiring where it connects behinds the ignition key.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Sounds like a high resistance joint somwhere in a main fuse somwhere(coroded or loose fitting). Whats the voltage in the light cct when they dim. Possibly check the a/c voltage as said above as 14.6v does seem high and it still might be a dying reg. It also might be the lug for the main V+ at the back of the alternatot - somtimes the wire burns inside the lug due to poor fitting lug.
    Reaper
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    cheers guys will check all this...might even throw in a new regulator for good measures:P
    VrWagz1's Avatar
    May 2008
    wollongong
    also have you measured if any ac voltage exists, that will indicate a dead diode too
    Reaper
  1. vr electrical problem
    By bhoys88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-06-2008, 11:40 AM
  2. Electrical problem with VN
    By enrico in forum General
    Last Post: 13-12-2007, 03:59 PM
  3. vk electrical problem
    By old55 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-02-2006, 09:15 PM
  4. Odd electrical problem
    By Indy_387 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-06-2005, 05:43 PM
  5. Electrical problem
    By xr_MAD in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-06-2004, 12:47 AM
