Hey Guys,
Have just replaced the Rubber Seal around the drivers side and now my drivers side door will not shut right up. He will shut to the point where it wont move but it is sticking out a bit. Here are some pictures
Any Ideas
Mumbo Man
inside the door (On the car body) there is a loop that the door latch clicks onto, it has two torx screws holding it in, undo the screws slightly, move it in a little and re-tighten, then try to close the door :P
I'm slightly drunk so I cant be more specific, sorry.
Cheers BuddyMight go out now and attempt. I know its 8.30 at night but I'm bored.
I'd go with what DannyboyDS says unless the door striker has never been previously adjusted....if never adjusted new seals should still close....have you shut it "firmly"
I've also heard that some new rubbers are slightly harder than original factory rubbers which may make an adjustment of the striker necessary. Maybe I've also had too many beers as I think I'm writing the same as DannyboyDS.
Any ideas? LOL I guess it would be the door rubber :P
Sorry - Havent had ENOUGH beers
Current mods/repairs:
Power Windows Installation (70% Complete)
Current Issue(s)
N/A
My Holden doesn't leak, It's just marking it's territory!
you have to watch out doing that :P some wierdo the other day got all shirty with me for writing the same thing as him differntly, as if I had gone out of my way to do it, just an accident tbh.
Anyway following on from that you can always re-check the install and make sure everything is in place, then try to get an eye on the exact point it is fouling at when you close the door, the hinges are ok yeah?
[QUOTE=DannyboyDS;1089254]you have to watch out doing that :P some wierdo the other day got all shirty with me for writing the same thing as him differntly, as if I had gone out of my way to do it, just an accident tbh.
/QUOTE]
I had the same deal when I expanded and simplified another forum members post that was very brief and used highly technical terms. Ah well, imitation is the sincerest form of flattery.
Re the door seal:
You can also use a sheet of A4 paper - insert it at various points around the door opening and then shut the door - then pull the paper out - if it is hard to pull it indicates the seal is tight there...or slides out easily means the rubber is barely touching.
