Hey everyone im new to the forums and just got myself a VS Commodore:P
am looking at buying newer rims for my car and was wondering if SS rims will fit on her. Is there a pre(model) or something?
Cheers,
what model are the rims off?
what helrzr925 said + if there 17s or 18s they should fit with out a problem unless there off a ve in witch case the will need to be machined. but it depends on your suspention mine will only take 17's
Wheels from a vb-vz should go straight on a vs as they are all the same stud pattern and pcd. Generally you shouldn't have too many dramas unless you start changing things like offsets and your car is lowered.
If they are Ve rims to fit VB-VZ you will need to get 5mm spacers to clear the strut towers. I had too on my vr that is running ve caprice 18s they are 240/45s not much room under there now. Don't go any lower than 30mm if you lower it unless you roll the guards or they will scrub too
