Results 1 to 7 of 7
Thread: Vs help
    VS Wagon VS
    Mar 2009
    Default Vs help
    Hi guys im new here.
    I have a vs wagon on gas. It is running shocking on petrol and perfectly fine on gas. when it idles on petrol it sounds like it has a lumpy cam in it.
    Here is a video of the car. would be great if you could help or tell me how to fix.
    SV62NV's Avatar
    SV62NV is offline Scuba Steve
    MY09 VE SV6
    Mar 2009
    Kurunjang
    my mate had the same problem with his car, he went and bought a normal exhaust and the problem stopped, mite not be the same with u just a suggestion.
    cheers, shane
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    My first though is one or more dirty injectors as you say it runs OK on gas (rules out ignition) - put a can or two of injector cleaner thru the tank and see if that improves things. It's not blowing black smoke so it's not running rich.
    And welcome to the forum.
    VS Wagon VS
    Mar 2009
    thanks guys will try injector cleaner and see how things go.
    Could it also be a dud valve or not?
    cheers
    96 VS Executive S II
    Feb 2006
    Perth,WA
    I have the same issue on gas, runs soo bad but fine on petrol, sorry i cant help tho, i still trying to figure mine out =)
    <insert something funny here>
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by vswagow View Post
    cheers
    A dud valve will be felt on gas as well - as it runs OK on gas the valves must be OK. May also pay to replace the fuel filter as a long shot...probably due anyway!
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    That sounds so very wrong, giving it runs on gas fine i would say check out the fuel system. As said injectors would be high on the list.
    Reaper
