Results 1 to 8 of 8
Thread: VR Overheats
    Vr S2 Calais
    Jan 2009
    Default VR Overheats
    Hi all i have a Vr calais s2 and it keeps over heating i have replaced the thermostat with low temp one also top rad hose and replaced coolant but when it over heats i dont hear the fan cut in so i curse to see if its the fan if it is how do i test it to see if it works also what else could be the problem
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Turn on the aircon and the fans should come on, at least you will know if the fans work.
    MY RIDE
    SV62NV's Avatar
    SV62NV is offline Scuba Steve
    MY09 VE SV6
    Mar 2009
    Kurunjang
    i have the same sorta issue with my vs v6, when im stationary the temp gauge goes straight up pretty close to high, as soon as i take off and get the air moving straight back down to the bottom...
    does ur vr overheat while just driving?
    Vr S2 Calais
    Jan 2009
    both when driving but most of the time stationary i turned the aircon today and i couldnt hear any fans
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If the fans don't come on with the aircon it would suggest the fans aren't working. Check the fans are plugged in to the loom properly, also check the fan relays and fuse if there is one, I can't remember.
    MY RIDE
    Vr S2 Calais
    Jan 2009
    VR Calais
    Mar 2009
    yeah all i could suggest is make sure the plug is connected properly to the loom on the left side of the radiator. if it is get a test light make sure that the car is running with the A/C on and test if there is power to the connector (plug). seen a few that have had faulty power connections in the wiring.
    Vr S2 Calais
    Jan 2009
    hi fellas well i took out my radiator and took it to the happy wash and high pressure rinsed it replaced the thermostat with one that will open earlier i replace the bottom radiator hose because it was bolging put new tectaloy gold coolant in it and ran it it ran fan came on and now dont go any further than half way so i think it may have had an air lock also the radiator cap which was in it wasnt a recovery one just standard so it wasnt taken in any coolant from reservoir never buying parts from repco again anyway cheers fellas for all the ideas
  1. Vs overheats
    By whippet in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2008, 04:06 PM
  2. Overheats Resonably Quickly...Why?
    By GAMBLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2007, 07:01 PM
