Results 1 to 7 of 7
Thread: Vr Head replacement
    VL EXEC
    Aug 2008
    perth wa
    Default Vr Head replacement
    There is a vr acclaim at my work that has belonged to a women since new i can purchase said car for 1500 everything in and out on the car is immaculate bar one small dent under the tail light, only issue is the heads gone do u rekon itll be better just to fix the head or get a new engine? and how much do u rekon ill be paying all labour will be done myself at work and in the long run is it worth it?
    I've driven fast cars I've done stupid shit in them each time i seem to come out on top i love you guardian angel
    vp ss 3 months to go
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Which head? or both heads? It's a V6, this one, not something you're used to
    2nd hand motors are cheap as.
    WTB: mulberry VN interior parts
    VL EXEC
    Aug 2008
    perth wa
    i dunno which head it is im used to 4s and straight 6's dammit
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    you can pick up reco heads from places like repco, but i think they're something in the order of $350 each plus your old heads. the spanner work is easy, these engines are life-sized mecchano (if you had that as a kid)
    engine replacement would probably be easier, most likely cheaper (if you get one from a wrecker) but then you risk buying a dud. it's really something you need to weigh up pros and cons of each solution and go from there
    oh and the easy way to check which head is to do a compression test
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    VL EXEC
    Aug 2008
    perth wa
    ill try pull an engine out the quokka for a few hundred probably alot easier then ****ing around the rear seal on the engine is gone to apparently so an engine replacement seems the go
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    VL EXEC
    Aug 2008
    perth wa
    the boss thinks its pretty ****ed and even he says its prob better to get a new engine
  1. VE Head unit replacement.. PLZ HELP
    By Lumina439 in forum Car Audio
    Last Post: 28-06-2011, 08:46 AM
  2. battery replacement in vs key head
    By carpetsnake in forum General
    Last Post: 18-11-2008, 06:12 AM
  3. VR Head Gasket Replacement
    By boogs86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2006, 09:07 AM
  4. VR Head Gasket Replacement
    Last Post: 01-06-2006, 06:33 PM
  5. Vn Head Gasket Replacement
    By James Collins in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2003, 07:18 PM
