Page 1 of 2 12 LastLast
Results 1 to 25 of 39
Thread: Best way to clean battery
    WogBoyz's Avatar
    WogBoyz is online now Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Question Best way to clean battery
    the name says it all ^^
    i dont really wanna disonnect the battery encase it resets something but will just spraying good amout of dregreaser on it and a brush clean the terminals up nicely then wash it off?
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Only thing it should reset might be your radio presets. If you have a factory radio, make sure you have the pin number, but other than that there's no problem disconnecting the battery. It's a common thing to do when you work on the car.
    As for cleaning it, just use a wire brush to clean the terminals, and use a damp cloth to wipe it down. I wouldn't spray degreaser on it, if it's really grimy maybe spray a little on a rag and wipe it, but don't go nuts.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    u can poor hot water over the terminals, will get rid of any build up, but if you want to clean em good, u'll have to disconnect them and attack em with a wire brush.
    EDIT: danja bet me to it
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    ahh kk yeah i got factory radio dunno its PIN tho wud spraying a lil bit of degreaser on the connecting be ok just to sofen the muck up (i got a lil pile of it there) then just use the wire brush to clean it up
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    oh ok ive never disconnected them before aye, anyone wanna explain it to me
    Haydz's Avatar
    Haydz is online now Fasten your seatbelts
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    awsome, now what will happen to my radio as its the factory one?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    lol dude ur funny
    just in case ur serious yes we all have to start somewhere
    10mm socket or spanner, undo the nut (u dont have to remove it) then it should be loose enough to wiggle off, wire brush the battery terminal (carefull not to short the 2 together) then wire brush the wire terminal (the big loop, dont know the proper name) then place the ""the big loop"" back on the battery pushing down all the way, then do up the nut again.
    repeat the other terminal
    VS Berlina SII eco
    Jan 2009
    bit of soapy water and a rag should do the trick, if its in the vs wouldnt worry bout reseting things as long as uv got the stereo codes
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by ephect View Post
    lol dude ur funny
    thanks for that, thats the details i was after lol
    where will i find the codes for my radio?
    VY SS
    Jun 2006
    Albany
    warm water with some bicarb soda will help clean it up, it would be better to take the battery out so you can clean it better. while your at it check the fluid levels and top em up if needed, just make sure you dont overfill em lol.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    lol yeah thats a good idea taking it out, nah i know not to over fill them, do you's just use normal water or distilled water?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    normal water is fine for washing, topping up the battery cells use distilled water
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    kk cheers for the help everyone
    your good lads
  15. #15
    danja's Avatar
    Jan 2006
    Not sure if the VS radio was coded, someone else might be able to help, but assuming it is the code is often written inside the cover of your car's manual. Otherwise Holden are able to find it for you, but depending on where you go they might want a fee for looking it up.
  16. #16
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    yeap VS has the coded radio. As danja said, should be on the inside of the manual if you have one, or you can provide the VIN number to holden and they can look it up for you, some charge you and some dont.
  17. #17
    the collector is offline the collector
    rodeo dual cab
    Mar 2009
    adelaide
    Default terminal
    hot water on terminals/wire brush
    degrease the engine bay while youre at it
    and blast the whole lot off
    spray some battery treminal protector on afterwards ( super cheap etc)
    wash the whole car while youre at it
    cheers
  18. #18
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    oh ok thanks man, how much is the terminal protector stuff?
  19. #19
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by axemurderer101 View Post
    I'd agree with this method and then as others have said, a wire brush if necessary. Once they're all clean give both the battery posts and terminal clamps a light wipe of grease. This will prevent any further corrosion for a long time.
    As for the standard vs radio, yes you will need to re-enter the 4 digit pin code once the battery is reconnected. As far as I know you are able to obtain this pin for your car from any holden dealership if you can provide them will all paperwork and proof that you own the car in question.
  20. #20
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Take the (-) battery terminal off first. Just noticed this has not been said before.
  21. #21
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    i had a look in my manual and it said my secrity pin number will be on a plate or something in my glove box, i have a quick look but i cant find anythiing, does anyone know where exactly it is?
  22. #22
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    anyone know where it is??
  23. #23
    SHANBANGER's Avatar
    SHANBANGER is offline Der Meister
    1997 VS S2
    Aug 2008
    Kyabram, Goulburn Valley, Victoria
    Quote Originally Posted by WogBoyz View Post
    I had the same problem when i disconnected my battery. The code isnt in the manual and you will have to ring up your local holden dealership and they will give you the 6 number pin. Good luck mate
  24. #24
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    oh ok my book says its in my glove box, did urs say that too n it wasnt there?
  25. #25
    SHANBANGER's Avatar
    1997 VS S2
    Aug 2008
    My book also says that but the previous owner of my car must have taken it out of the glove box and failed to give it to me or had lost it. Now ive got the pin on a piece of paper and put it under the rubber bit in the space under my head unit. Cheers
  1. [VIC] Misc parts - gauge, steering wheel, speakers, battery cover, battery box
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 06-05-2009, 06:32 PM
  2. Clean VZ
    By scottie_vz in forum VY - VZ - WK - WL - V2
    Last Post: 19-06-2008, 12:11 PM
  3. carbon clean/injector clean
    By xcop5l in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-09-2006, 10:24 PM
  4. How to clean t/b
    By coolvxss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-05-2006, 09:32 PM
  5. F/S: Very clean 93 VR
    By Shifty1 in forum Parts And Other Items For Sale
    Last Post: 02-05-2006, 02:12 PM
