Results 1 to 12 of 12
Thread: brake pads and disc rotors
    damo15 Guest
    Arrow brake pads and disc rotors
    what sort of pads should i use and if i was 2 up grade my brakes how would i go about doings so? how much? where from? and what sort of rotors?
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    are you doing it yourself?...I got my vt brakes from a bloke at Ipswich and fitted them myself but there are a few traps for the uneducated.
    Mr spares can set you up its just the freight that adds a bit to the overall price.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    VE SSV Sportswagon, VK race car, Kwaka ZX12R!
    Oct 2003
    Bayside Melbourne
    2 ways to fix this.....
    stay with a VR/VS type rotor from DBA (slotted or drilled your choice)
    with say Ferodo pads... a nice cheap easy way to get better brakes
    ..no mods works well (I have this on the VR and its good)
    or
    go to the VT/VX rotor and caliper upgrade with matching pads
    more expensive and has its problems..most get it to work in the end
    but it does stop a bit better
    hth
    Smitty...with the VE SSv SII Sportswagon, VK race car and... Kwaka ZX12R
    damo15 Guest
    yer i probs go with the slotted DBA and ferodo pads, my dad n me will do it anythin i should know about doin it? how much will it cost around about all up?
    Oct 2003
    Bayside Melbourne
    the DBA/Ferodo upgrade is easy
    with car safely up on stands.... (not on jacks)
    remove rotors after first removing calipers (remove road wheels first )
    the original ones may rust to the front bearing hub so they need some persuasion to come off (backs should come off if handbrake off)
    put new DBA rotors on (after removing disc Rustguard with petrol or Prepsol)
    put Ferodo pads in calipers
    put calipers back on
    ....can I suggest a brake fluid bleed/flush here also
    then go and bed in Ferodo pads as per the instruction sheet
    and
    you are done
    damo15 Guest
    VS Acclaim
    Mar 2004
    Melb.
    Roughly, $75 for new rotors each, + $60 or so for a set of front or rear pads.
    Forgive me if I don't reply to a query straight away. The E-mail notification function only works 50% of the time for me.
    CHA55A Guest
    Definately go with the DBA's.
    Ive got the cross drilled/slotted on front and rear and personally I think its the best investment Ive made.
    Granted your tyres are in good shape, the brakes/discs bettered my expectations. Not neccessarily in fast situations, but those times when people/cars jump out infront of you out of nowhere - they handled perfectly.
    VT Acclaim 98
    Jun 2009
    Hi just got my brakes little less so went to mchanic whoc advised new brake bads and discs and quoted $300 for everything..was wondering if its ok for this much price?? or should i look for some second opinion...advise is helpful
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by sachin.sachdeva2 View Post
    THREAD DIG!!! lol.
    Depends on what brand/quality of rotor and pad he is fitting.
    But for $300 bux including labour I wouldnt imagine it to the that great of quality, personelly Id rather spend big on my brakes and go with high quality parts.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    $300 seems right, good price actually, as $45 to $60 for each rotor, and set of pads. he charging it seems $150 for labour for nearly 2 hours work, seems fair. Make sure he flushes the brake fluid as well in that price. Is this for fronts only, or rear as well ?
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by vxcalais_01 View Post
    Oh didnt think about that, I assumed the poster meant all 4. Agreed not a bad price if using quality rotors and pads for just the front or back. If its for all 4 then no, he has to be using shit stuff and charging next to no labour.
  1. [VT-VX] How to: Change pads and rotors.
    By 253@7k in forum Holden Commodore How-To's
    Last Post: 13-05-2012, 08:30 AM
  2. VN - VS: Replacing the Brake Pads (Disc Variety)
    By Darren in forum Holden Commodore How-To's
    Last Post: 29-01-2011, 02:05 PM
  3. Replies: 2
    Last Post: 01-02-2007, 11:12 AM
  4. Which Disc Pads to buy??
    By Jock in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2006, 09:24 AM
  5. New Pads, New rotors - Beddding in?
    By LaShY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2005, 11:00 PM
