Results 1 to 7 of 7
Thread: VR calias 1993 misfire
    VR Calais
    Mar 2009
    Default VR calias 1993 misfire
    hi all got a VR calais.
    it misfires underload in drive, cahnged the plugs and leads but misfire still occured... swapped a coil pack off a VN but misfire was still there.
    anyone got ideas of a fix for this problem??
    should i try a brand new coil pack??
    thanx
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    How old is the harmonic balancer and CAS?
    and 3 Dangerous non ABS VN's
    VR Calais
    Mar 2009
    the harmonic balancer was replaced bout a month ago but not sure about the crank angle sensor. checked codes today on the computer but no codes.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by smarty091 View Post
    The 3 mail things are CAS, DFI/Coils and leads for a braking down under load.
    But also can be the fuel pump/regulator on the way out and not delivering enough pressure.
    VR Calais
    Mar 2009
    Quote Originally Posted by 88GreenVN View Post
    ok so you reckon i should change the crank angle sensor and see how that goes??
    Vr Executive 3.8
    Dec 2008
    My vr was doing this recently and it turned out that the alternator putting out the wrong volts was the cause of alot of problems...misfiring, stalling, gearbox going into limp mode, stereo going nuts, put another alternator in and its all good...just something to keep in mind
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    id say its a stuffed lead
  1. V6 misfire - where to next?
    By Longman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-09-2010, 04:34 PM
  2. Misfire ????
    By ecotec38 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-02-2008, 07:01 AM
  3. misfire
    By immortality in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2007, 11:08 AM
  4. misfire?
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2006, 02:26 PM
  5. vt misfire
    By linc in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2005, 11:57 AM
