Results 1 to 11 of 11
Thread: How low do i go?
    VS Commodore series II
    Mar 2009
    Port Macquarie
    Default How low do i go?
    just thinking of lowering my VS II V6 live axle, cant really decide on what to get. could someone guide me, mabey with pics on what to get.
    i definally want it to be legal and not scrape, but i want something that sits nicely, can someone shed some light? (pics would be awsome)
    -ToM-'s Avatar
    -ToM- is offline Bow Down to the Emperor!
    VR Exec [EMPIR3]
    Jan 2008
    SA
    VR V6 Live axle King springs Superlow all round, monroe GT Sport shortened shocks, thinner rubber seats top and bottom
    I get absolutely no scraping/rubbing, and i can take most speed bumps with a little bit of speed
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Quote Originally Posted by -ToM- View Post
    [/img]http://img26.imageshack.us/img26/7247/sl373642.jpg[/img]
    [imf]http://img4.imageshack.us/img4/3457/sl373634.jpg[/img]
    hey mate were your springs bedded in when you took the pics or not quite?
    Cheers.
    VR Equipe II
    Mar 2008
    QLD
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    VR Equipe II
    Mar 2008
    QLD
    Dec 2008
    VR Berlina
    Feb 2005
    bendigo, vic
    heres mine with 17s and one with 20s. kings superlows in the front and ultra low in the back. with the 17's it sat at 70mm clearance and 105mm with the 20's. i reckon its a good height.
    Attached Thumbnails Attached Thumbnails How low do i go?-dsc00622.jpg   How low do i go?-11082008226.jpg
    Fun_Bucket's Avatar
    Fun_Bucket is offline Gay Country Rapper
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Depends also on what size wheels you will be using. It's a good idea to go one step lower at the back, for example, superlow in the front, and ultra low on the back, if you want a level ride height, if you fit the same height springs all round, you'll find that the arse end will sit up a little higher.. If your using stock wheels, and still wanting to keep it leagal, then i wouldn't go any lower than superlow in the rear, and standard low in the front. Any lower than that, and you'll be looking for attention. If you plan on fitting larger rims, 17's or larger, then you can get away with Ultra's in the back, and super's in the front, just like the pictures above by Krizko, notice the pictures by Sweetfu, his back end sit's up just a tad higher with the same springs all round...
    Mar 2009
    Port Macquarie
    oh sweet thanks for the replys, been an awsome help, thinking of getting 17's and then going ultra in bank super in front, do i need better shocks/struts?
    VR Berlina
    Feb 2005
    bendigo, vic
    you will definitely need shorter shox in the rear with ultras... they tend to fall over if you jack it up. the front should be fine, but couldnt hurt to replace the shox while its apart anyway.
