Results 1 to 5 of 5
Thread: tail shaft
    Vs Commodore, Vr Acclaim
    Feb 2009
    Default tail shaft
    Hi there, i have a vr sedan with irs and also a vs solid axle donor car. Are the tailshafts interchangable? Also i have read some other posts about changing these and it is mentioned to mark the spline? Any tricks or tips on how to remove one and put another one in would be greatly appreciated, cheers
    Marcho is offline Marcho"s R.I.D.E
    VR Accliam S2
    Jan 2009
    Armidale N.S.W
    I think from memory that they are mounted different under the car. You would be able to do it but what it will cost you will be more than the car is worth.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'm not 100% sure if they are exactly the same - but fairly sure they are. When removing plug the rear of the trans to stop oil escaping....mark the whole tailshaft wherever it separates with a centre-punch so it goes back exactly the same and do this before removing or use quickdrying paint. try to make sure the centrebearing goes back to the exact same position and watch for any shims. Take your time and plenty of measurements!
    Good Luck.
    Feb 2009
    Thanks for that, but the replys are 50/50 yes/no. any one know for sure as i need to know before i start pulling stuff apart, cheers
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If you have a donor car, pull the tail shaft out and then lay underneath the VR with the tail shaft and see if it all lines up.
    Visit my Facebook page
  1. tail shaft
    By Disturbed_vegeta in forum V8 Development and Modification
    Last Post: 13-09-2008, 07:18 PM
  2. tail shaft IRS
    By LOWPSI in forum General Discussion
    Last Post: 15-05-2008, 09:26 PM
  3. Tail shaft
    By Idenity Crisis in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-10-2007, 09:41 PM
  4. VB Tail Shaft
    By B.C in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-04-2007, 10:14 AM
  5. vt ss 5.7 tail shaft
    By evets in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2006, 12:02 PM
