Results 1 to 7 of 7
Thread: How can you tell if your water pump is on the way out
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Default How can you tell if your water pump is on the way out
    When driving along normally, the temperature gauge sits where it should. Going up hills, sitting at lights etc, the temperature goes up to about half way, and the fan kicks in - all good.
    However, after going up a hill then cruising again, it is taking much longer than it used to for the temperature to come back down again.
    The thermostat is new, as is the sender. The radiator doesn't appear to be blocked inside or out.
    Causing no hassles at the moment, but I am interested if it is indicative of a developing problem.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    - rusty water leaking out from under the pump pulley/ or general loss of coolant
    - rattling or squeaking from the pump area, with overheating
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    VZ SV6
    Oct 2008
    Newcastle NSW
    mine was cooling normally but making an intermittent 'click click click' noise at idle (ie. bearing going). it wasn't in speed with the engine.
    aceventura's Avatar
    Mazda 6
    Oct 2008
    SEQ
    Thanks guys - Mine certainly isn't displaying any of those symptoms.
    But I seem to remember some posts where people report when they pulled the water pump out, the fins were basically missing due to corrosion. This would hinder circulation of the water.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If the impeller fins on the waterpump were corroded off it would mean they were not using the proper coolant - if you're running proper coolant it should be OK.
    Croydon is offline Croydon
    VR Exec 3.8 auto wagon, bench seat
    Jun 2009
    NZ
    vs ute
    Sep 2008
    most water pumps have a small drain hole just under where the shaft comes out of the housing, this goes into a chamber behind the bearing and seals.
    when they start to go you will get a small amount of coolant leaking out of this hole, this is first signs of water pump becoming cactus, might be old or belt might be to tight?
    When the bearings go they tend to make a fairly annoying rattly noise as well.
    The blades can start to corrode away to nothing which will cause a massive loss in coolant flow which will cause over heating, this can be caused from a few things.
    bad/old coolant
    no coolant
    mixed coolants or additives which shouldn't be mixed
    bad engine earth connections
    if you stuck in a new thermostat, maybe pull the rad out and give it a pressure test from a proper radiator joint, that will make sure its not blocked as although there may be flow through the radiator it may not be going through the hole radiator getting max surface area.
    if still nothing then just replace the pump anyway, there not expensive.
    Use good coolant and make sure you flush and bleed the system well, eg stick a garden hose on one of the heater lines going into the firewall that is opposite direction of flow, this can get rid of any blockages in the block, head, hoses and heater core.
    after those few things it should be pretty sweet.
  1. Vs water pump - Electric pump.
    By Lazin in forum V6 Development And Modification
    Last Post: 06-05-2011, 07:08 PM
  2. Probably the water pump?
    By StockoVRWagz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2008, 08:13 PM
  3. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  4. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
  5. Water Pump
    By VScom in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2007, 11:12 PM
