Results 1 to 7 of 7
Thread: code48?
    vr wagon, vx executive
    Jan 2005
    Default code48?
    no signal to cam angle sensor. on vr series 2 v6? check volts to cam angle sensor at plug. all good going by gregory manual. replaced cam angle sensor. all good. replaced dfi and coil pack. all good. replaced leads and plugs. motor still works the same. removed engine fuse as manual says to reset error codes. i have done everthing that the gregory's manual said and still getting error code 48? help please
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    did you change the cam angle sensor or the crank angle sensor by mistake there is 2 on VR just making sure you changed the right one.
    Jan 2005
    i did the crank angle when i put the motor together and the cam angle sensor when i had the motor in the car and the code came up.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Maybe try another ECU - they're cheap as dirt nowdays...well, cheaper than a CAS. Or try unplugging the ECU and leave overnight. Is the engine is running poorly or using heaps of juice?
    Jan 2005
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If plugs and leads or OK I'd drive it and not look for trouble. 220k for half a tank is good. Keep your eye open for another ECU...they go for a little as $10. With what you've replaced already you don't have many options left. Frustrating I know.
    Jan 2005
    i will get the ecu and some other good bits off the young guy around the corner from me. he smashed his vr and i got the extractors and full 2 1/2" system off it for $100. i starting to think about leaving the error code there as the car is going well.
