Results 1 to 6 of 6
Thread: Help with Vibration
    1994 hsv senator
    Apr 2007
    Jindalee
    Default Help with Vibration
    Hey everyone this is my first post so if i screw it up please tell me
    Ok so i recently bought a VR Senator with 205ks auto but only 185i
    On my first cruise with a work mate i pulled up next to a hsv enhanced statesman. Off the line we both floored it until i backed off due to a very bad vibration coming from everywhere. I have asked all my fellow commodore owning friends and have been told check the uni's centre bearing harmonic balancer engine mounts and if the tail shaft is balanced.
    All of these have been checked and seem good. Does anyone have any other ideas of what this problem could be?
    thanx in advance
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Welcome to the forum and your first post seemed pretty good to me - you described the car, the fault, checks that were made and results and finally asked for ideas.
    Most Commodores have bad vibration in first and second when floored. If you have a solid rear end I'd check the control arms on the diff as they can make the vibration worse. If it's OK at slight and moderate acceleration then I wouldn't worry...but that's just my opinion.
    Good Luck.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    welcome. hako is right, check the top trailing arms for the diff if it's the trailing arm setup (solid dif axle), if it's IRS then check the diff cradle for cracking and the diff mounts. also check the trans mount. although the trans mount (and engine mounts also) may look fine, they will be sagging some by now if they are the original ones. combine that with the aging rubber and vibration will be your friend.
    then there are the simple things like wheel ballance and alignment. combine this with doing a full service (all fluids/filters/plugs/leads etc) will help get the best from your new ride.
    Body by Holden, Soul by Brock
    the Legend will live forever
    1994 hsv senator
    Apr 2007
    Jindalee
    Ok i think its been found. had it up on a hoist today and drivers side engine mount bracket is cracked actually its almost compleatly seperated from the chassis so all the mounts will be done next week anyone got any idea how much i should expect to be charged on the card for the 2 engine and 1 rear tranny mount to be done
    Cheers all
    VR Berlina
    Feb 2005
    bendigo, vic
    last i checked, mounts were between $50- $90 each. i got my in law to fit my mounts, so i dont know how much they will charge for labour, shouldnt be much tho.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Expect to pay $300 for pass side and another $200 for the other 2 mounts...so $500 unfortunately. Passenger side is the hard one.
  1. Vibration
    By lilzen96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2008, 02:19 PM
  2. VZ Vibration
    By Clinster in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-08-2006, 07:55 PM
  3. VP Vibration-WTF
    By Jamie_87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2005, 05:27 PM
  4. vibration
    By remmie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2005, 06:29 PM
  5. Vt vibration
    By satos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2005, 11:18 PM
